We (@gnarlynick2072 and @teedigs) are getting pretty excited to swap the 5spd into our 80s. There is one thing about swapping an h151f that we haven't seen adequatly addressed: The Neutral Safety Switch. Which would normally be found on the clutch pedal assembly, requiring the clutch to be depressed to ensure the vehicle is not in gear to start.
These transmission can be installed but with a small work around that will interfere with the cruise control, which can be fixed with another work around: a switch which disconnects that neutral circuit to allow the CC to function.
Apparently on early models there is no NSS, or rather the truck can be started IN GEAR. It seems possible that some of these models did not come with cruise control.
But later models must have had a factory h151f and factory cruise control without any conflict or need of some Frankenstein switch solution.
I've been looking on various parts supplier websites, toyodiy, and the FSM but I can't find any indication that there is a switch on the clutch assembly.
Apart from a vague reference by landcrusher80 (who in the end used a switch on his dash).
Does anyone know anything more about this issue?
