H-41 to 3speed transfer case (1 Viewer)
middle tn
I have an older, 10 spline h-41 that I’d like to mate to a 3 speed transfer case that I also have. What do I need to make this happen ? Thanks I’m advance, Rick
The ten spline was nevering imported to the US so not familiar with them. Is currently mated to a transfer case? If not post a picture of the transmission output shaft. If it does have a transfer case how many teeth on the input gear? Twenty nine and at the very least should be able to use the three speed idler gear and low range output gear in your current transfer case. This is provided you have a three speed transfer before they switched to wider gears with thirty one teeth on the import gear.
x2, I'd love to see the rear output shaft. If it is indeed 10-spline, you shouldn't need anything to mate the two.
If it's 16 spline, you need this:
If it's 19 spline, you're out of luck short of custom parts.
