admittedly i’m new to off roading, but will say that the safe jack base, or any similar base, attaches to the jack.
it’s not just a hard plate that the jack sits on. it has some screws that hold down the jack to the base, making it act as one unit. the other bases just seem to be a hard flat surface.
does the jack move independently when using traction boards or the plastic hi lift base?
also , to make sure i really blew my budget, i bought the safe jack accessories, then decided i needed a tertiary solution and bought a 1.5 ton off road jack +agm jack rod . now thinking of the 1.5 ton badlands version. i have a tool collecting problem.
this is also now catching my attention: $400 scissor jack
Heavy Duty Universal Scissor Jack by Agile Offroad - Agile Offroad
Heavy Duty Scissor Jack by Agile Offroad. A robust and reliable jack that is the perfect scissor jack for Sprinter vans, RVs and rigs of all sizes.agileoffroad.com
Most ridge running woodchucks grew up using farm jacks (the original hi lift) and a come a long (cable puller). Can do everything from pulling a breech calf to stretching barb wire and fence posts with those 2 tools. When lifting with a jack you know as soon as it starts to move off vertical with a slight tilt to lower it and start over. I think where people get in trouble is when they don't lower it and continue anyhow. And to keep your face and body parts away from the handle of a hi lift and make sure it fully seats at each ratchet. Just like a pump shotgun, don't short shuck it.
There are times having a jack slide off is what I want, as long as it is controlled, it is how I get off being high centered. Lift and push, or if you have to use the cable puller pull it off the jack. Of course you don't want the body of the hi lift coming into the body of the rig, push so that it falls away from the body.
I carry a 24" scissor jack with me for the trailer and also for the Polaris Ranger. Just a basic $50 scissor jack, not one all fancy with a torque multiplier like that one. I carry my battery operated impact driver with an extra battery to spin it so guess you could say that is my torque multiplier. Don't really need to even at my age, but it does make things go a lot faster when you do need to use it.
But for the GX so far I'm happy with the OEM jack and stacking plates in the woods. Where I get cell phone reception I'm calling USAA roadside assistance LOL. I worry more about idiots flying along the road on their phone with me changing a tire next to them then doing it in the woods.
