GX460/5th Gen 4Runner rack
I did this over the last three days (kind of.)
I had a suspect inner tie rod on an original steering rack on my 2006 GX470 with 185000 miles, a filthy reservoir, and a desire to not touch the front end again for a long time. I recently replaced the LCA bushings with toyota ones, 555 lower ball joints, all Toyota KDSS bushings, and Dobinsons UCA. I did Dobinsons IMS front struts about 3 years ago and hope they have a lot of life in them yet.
I ordered the following parts:
90119-14138 Genuine Toyota Bolt, w/Washer - https://www.toyotapartsdeal.com/oem/toyota~bolt~w~washer~90119-14138.html x2
90178-A0058 Genuine Toyota Nut, FLANGE - https://www.toyotapartsdeal.com/oem/toyota~nut~flange~90178-a0058.html x2
You also need a 9/16 drill bit or reamer, and a 17mm or 11/16 crowsfoot. I might have never got the intermediate steering shaft off without my air hammer.
I did this on jack stands in my driveway. More than anything it was an exercise in being patient when trying to get the intermediate shaft off, and the rack in and out. Wheels off, KDSS sway removed.
I took both outer tie rods off from the start, the passenger one could probably stay but it took a minute and made things easier.
I removed the high pressure line first, this is probably the worst one. DO NOT try it with a normal wrench, you're way too likely to round it. Use the crowsfoot here. A flare nut wrench would not line up in my efforts.
Once the two lines were off, I went at the intermediate shaft. I used some heat, but I think the air hammer was what worked.
Then the two bolts. I put a bottle jack under the oil pan and relieved some pressure on the engine. I also unbolted the front diff supports and let it hang down some. I also removed the oil filter for room.
Turn the rack all the way to the passenger side, twist, pull, push it far enough over to pull the drivers side out of the tunnel, and that's the hardest part of the removal.
To replace, I unbolted a few metal wire clip points hanging down by the front of the engine, you may or may not find this useful. I think unbolting a motor mount or both to raise the motor would be the most effective.
The GX460 rack is slightly bigger all around, and the bolts are bigger. This is where you use your reamer or drill bit to open up the holes. My first expensive drill bit broke within seconds, the guy at the store said it was my fault as "it's impossible to drill mild steel out from 7/16 to 9/16 with a drill bit." But, I did it with a much cheaper dewalt bit from home depot, so I dunno. Lots of people on GXOR reported doing it with a normal drill bit too.
Getting the rack back in place was suuuuuper frustrating, but once you find just the right orientation it just kind of rolls in. The KDSS ram on my truck was a major obstacle that most of you won't have to contend with. Eventually I zap strapped it to the rad support and that helped a bit.
I drove the bolts up from the bottom after wasting some time trying to figure out how to tetris them in from the top.
Reassembly from there is just reverse, I did a toe alignment with the wheels in the air and piece of string ran front to back of the truck, index of the hubs with a micrometer to align. I think I got it pretty close. Certainly well enough to go get my alignment in a few days.
Given that the 460 rack can be found for around 700 bucks and is heavier duty all around I think it's worth doing. Perhaps worth paying someone, I was also chasing a squeak in my front end while doing this so I can't say the exact amount of time, but I think I was about 8 hours into it, that's including changing the reservoir. I've heard of people doing it in 3-4, and perhaps if you started with just lifting the motor to maximize space, you have really good spatial reasoning and essentially roll the rack in and out, and you don't run into miserably stuck parts like the intermediate steering shaft, it would be possible.
I've seen some bizarro videos with people disconnecting coolant lines, removing the driver's inner tie rod, etc but none of that is needed. I didn't really want to tear the inner tie rod off of a brand new toyota rack.
Thanks for posting this, wish I would have known the 150 rack upgrade was not that big of a deal. I would have done it on my 470 when I replaced the rack with a reman rack.
Regarding the inner tie rod ends - it's actually no big deal to remove them and reinstall them. I pulled the boots and took them off in a few minutes, then re-installed without tearing them. Made sliding the rack in and out super easy on my non-KDSS rig. I also had to replace the high-pressure hose as it was totally rusted to the rack - I just cut it off and ordered a new one.
FYI, looks like a 5th gen reman rack is only $281 (including core charge - though they might not notice if a 120 rack was sent back) on RockAuto:
Getting ready to do my lca, and rack in the next couple of weeks and I am glad I came across this. How do you feel about the rack at this point and have there been any issues at all with it?
I had to do a zero point calibration a couple of times to get it to take fully. The only issue I had was that the VSC got a little too easy to activate in some very niche conditions, usually coming down my steep driveway and turning hard at the bottom to go onto the street. Mind you, I'm heavy in the front with a steel bumper, skids, 11k winch, group 31 battery, sliders, and run heavy springs. But I haven't had the VSC fire for months now. The rack itself is just fine.
I ended up outsourcing the rack work because I was too slammed with work to get it done myself (I work slowly) before leaving town. Shout out to Tandem Offroad for knocking that out so quickly for me and doing what seems to be a really great job. Got my rack directly from Lexus which came with the outer tie rods (as a by the way for anyone else that buys one directly from Lexus). I did not baby it on the trip (though there was nothing too technical or challenging) but it did wonderfully and seems to be a solid and great upgrade! Now I just need to find the time to get my filter installed but really loving the upgrade to the 150 rack!
Does the 460 rack use the stock 470 bushings or do those need to be changed over also?
As if this job wasn't bad enough, my bolt is misaligned by about 3/8" from the hole in the frame. So far I've attempted to move the rack via prybar and also ratchet strap. Spent well over an hour with no success.
That late night advice worked. I trimmed about 6.5mm off each bolt to drive them in from the top. Switched the passenger and drove in from the bottom. Still had to pry, but I got it to work.
Pro tip: if you need to pry, use one of the old rack bolts and put it through the hole for the differential support bracket and pry off the nut. This way you don't mess up the actual diff support bolt/nut
Did you have any issues with the mount for the new rack lining up? I drilled out the holes to 9/16, but the mount width is off by ~1/4". I checked vs the old 470 mount and the 5th gen mounts are slightly narrower. I think I may need to send the rack back. Really hoping that's not the case and that its my own fault/something I can fix
Were you able to figure this out?
This sounds like the same issue I had. See posts above. You can get it, but it's going to take some leverage.
Trying to order the 460 upgrade for our 04 470. Does the Toyota 44200-60223 come with outer tie rod ends? I'm reading conflicting info.
I tried finding my order and haven't found the exact part number to confirm part numbers (i ordered a refurb for a 4runner), but mine did not come with the tie rod ends. Also didn't come with the jamb nuts either (they are different than the 470).
