Coolant is also a anti corrosion product. Coolant with distilled water 50/50 is recommended. It also has a lower boiling point
You sure about that last one?
Check your thermostat if you have one. It's very common here in the tropics that you have none. Somebody threw it out.
Check your radiator cap for proper functioning. It should open when the pressure is too high and suck the coolant back in from the overflow tank when the engine cools down.
That overflow tank is not OEM but should have at least a tube attached so that the coolant is dumped on the ground and not spitting around in the engine compartment.
If you have been working on your coolant system, you'll likely have an air bubble in the system. This bubble will push more coolant out than necessary. This also causes the sucking sound that you hear when you remove the radiator cap.
Make sure that the nose is higher than the back. Jack it up, drive up the sidewalk, whatever.
Let the engine run and getting at work temperature with the radiator cap off until no more air bubbles appear.
A working gauge will help.
On our BJ's here in Costa Rica we have a "fixed" fan which means it will always turn, unless a PO did a modification or something else is wrong.
Rudi
Oh, and don't believe your mechanic.
Hmmmmm, I think you're right. My bad. I'll remove it from the posting.
Rudi
Nope, I had it for sale for 4 years. A few months ago I parted it out. Only the housing is left.Rudi do you still have some for sale??
