Held for 10 seconds to get a more realistic (higher) pyro number, pre turbo, done in 4th gear. eBay front mount intercooler.
I havent seen 200hp @ wheels on a 1HD-T before, so you could say I'm very happy
AFR's lean at 19.3:1 (usually for light haze exhaust power tune, 17.5 is ok) at the measured rpm point (3000) and above 19 from 1900 to 3100rpm.
Owner is modifying inlet manifold (boxing it out). I will provide photos to this, all instincts tell me it will lean off the AFR's further by evening the distribution of air between the cylinders.
After this, and the fittment of a Holley red in line fuel pump (as a kind of lift pump), it will be returned and afrs will drop to 17.5:1 for a power tune. On this basis, I would expect over 165kW, probbaly 170kW.
Owner is on holiday for a month or so (using this truck the whole time, so believe it or not folks, this is actually the "safe" tune) then will do the mods mentioned and a retune. Thats an excellent pyro pre turbo when sitting on 200whp!
