Battery
A battery stores power by separating charge in the form of chemical molecules in relation to metal plates (aka electrodes).
The great the amount of charge separated, the greater the PE. So larger batteries usually have more cells therefor can separate a larger total amount of charge therefore provide more power.
When you close a circuit that is connected off of the positive and negative battery electrodes, the ions in the battery fluid flow towards the electrodes of the opposite charge…creating a current.
How easily they flow is measured by a type of resistance inside the battery called impedance (Z). The lower the Impedance, the more current can flow and the more KE the battery can put out.
Impedance is similar to DC Resistance, but has two additional components to it. Those two components are captured in the quantity called Reactance (X).
Z = R + iX
Where Reactance (X) has a Capacitive and an Inductive component and mathematically i is the imaginary number equal to the square root of negative one.
Load test only measures internal Resistance (R) and not Impedance (Z) of the battery…it doesn’t tell you anything about what is going on with those two additional Impedance components:
Conductance test measures Impedance, but doesn’t give you information about the Reactance components of X
And this fancy test (which I never heard of before) called Electro-Chemical Impedance Spectroscopy (EIS) provides information of all components of Impedance (Z): Resistance and Reactance:
This is the website I got those images from...and the best explanation I found giving an explanation of how the tests are different:
http://batteryuniversity.com/learn/article/why_do_different_test_methods_provide_dissimilar_readings
