I just bought a 1994 FZJ80 that had a skip in it. I washed it off with Super Power and hosed it off and the skip is/was gone for a week until today.
Today I decided to replace the POS Bosch Platinum plugs with the OEM Densos from Toyota. BTW, it ran fine this AM....I was planning to replace the new cheap aftermarket wires at a later date.
( I ended up buying new OEM wire, cap and rotor today from cdan.....Thanks Dan. Can't wait for the big brown truck.
And thanks for the advice on the oil pressure readings being typical of these rigs....)
I had one **** of a time getting the plastic tubes out and pulled one of the boots off in the process. I spent 30 minutes with a wire bent at 90 deg. at the tip to get the bottom boot out. It came out in 2 pieces. I glued it back together with blue silicone gasket material.
THEN I used Parker Super Lube on the
boots so they won't be so hard to remove when I get the new OEM wires, etc in a few days.
Anyway, after I got everything buttoned up and started the 80, I noticed it was a noticable skip on several cyl. !!!
I double checked and had not crossed any plug wires.
QUESTION, could the Super Lube be causing a skip.??
I thought it would not be a conductor.
BTW, I had used some Dupont KRYTOX flourinated grease on 2-3 of the metal tubes originally for the same reason.
Is anyone familiar w/ KRYTOX ?? It is from the areospace industry from way back...it was from a family member that worked there years ago. It states it is inert...so I figured it would not be a conductor either.
Next question. If these silicone lubes are the culpret, how the H*** do I get it out of the metal spark plug tubes??
I am too tired to fiddle with it anymore today, and my back is killing me. But I am trying to figure out a way to clean the silicone **** out of the tubes w/o getting anything down into the cyl.....because the bulk of the silicone will be at the bottom and I will have to remove the plugs to clean it.
How about a tampon
soaked in Acetone or lacquer thinner ??
Sorry about the long post....
How about a tampon
