I found the kill switch button and it works as expected. When active, nothing happens, not even a crank. When turned off, it goes back to crancking with no start, no CEL. Waiting delivery of the fusible links and cleaning behind the dash. Thanks!
Please keep in mind that the starter circuit is separate from almost every other circuit on the vehicle. It has nothing to do with the ECU or any of the EFI components. It will have no effect on the CEL.
As posted in several other threads:
Below is a cursory check of all 3 fusible links in system. This assumes an unmolested OEM configuration.
FL AM1 - Dome lights working?
FL AM2 - When you turn the key to ON does the CHARGE LAMP light up?
FL MAIN - Brake lights working?
If yes to all 3, then all 3 fusible links are intact.
From another thread previously mentioned:
Fusible links are the very first thing to check (see above), followed by the 15 amp EFI fuse in the relay box on the left fender, followed by the 7.5 amp IGN fuse in the fuse block by the driver's left knee.
Use a meter to check fuses/links, not your eyeballs.
Once again, this engine WILL NOT RUN without the CEL illuminating with the ignition key in the ON/RUN position before cranking the starter. The CEL in that position is telling you that the ECU is not in a "ready" state and the engine will not fire. Don't even bother cranking the starter.
