'93 HDJ81
Beginning to baseline. Will update with pics when the weather gets better.
products.liqui-moly.com
- New 315/75/16 BFG KO2s
- ProComp 16" Matte Black Alloy wheels 7069
- ProComp ES9000 shocks
- 4" lift springs
- LCP Gullwing windows
- 23303-64010 OEM Fuel Filter
- Ran 2 cans of the LiquiMoly Diesel Purge through the fuel filter, plan is to run another 3-4 more.
Diesel Purge
Developed for cleaning fuel systems and injectors within minutes and restore lost power caused by deposits. Ideally Diesel Purge is added into the fuel filter housing. It will eliminate knocking, pinging and exhaust smoke. Improves start up performance.
- ACSD Deleted
- Cooling system flushed, OEM Toyota red coolant
- ATF replaced
- Transfer case oil replaced
- Differential oil front/rear replaced
- New BEBs replaced (3/16/19), pics in following post
- New OEM Cap bolts (3/16/19)
- 00295-00103 OEM Seal Packing / FIPG (3/16/19)
- 90915-30002 New OEM Oil Filter, still available (3/16/19)
- Liqui Moly DIesel 15W-40 (10L) (3/16/19)
- Liqui Moly Engine Flush (3/16/19)
- 1 can / 5 liters of oil, so you need 2 cans for a proper engine flush
Touring High Tech Diesel Specialoil 15W-40
Particularly suited for vehicles with high mileage. Mineral-based high performance motor oil. For the demanding diesel driver. Reduces oil thickening caused by drag-in of soot. Even under extreme operating conditions, it provides for a stable lubricating film. With modern wear-protection...
Pro-Line Engine Flush
The highly effective detergent and dispersant additives in association with the carrier fluid have been tested in the laboratory and in practical field trials for their ability to dissolve sludge and lacquer formers. All types of oil-soluble and oil-insol
- Oil Separator / Oil catch can (4/20/19)
- Mann Provent 200 install to eliminate oil migration rom crankcase to turbo and eventually to the intake
- Tailgate storage mod by Huracan Fabrication in AUS
- 80 Series Land Cruiser tailgate storage mod - https://hfabusa.com/collections/toyota/products/80-series-land-cruiser-tailgate-storage-mod
- Inspect brakes, rotors, brake lines
- need extended brake lines, some stretch while on a lift
- 17801-68030 OEM Air Filter
- Injector rebuild (PartSouq and ebay)
- 23620-17010 (093400-5770 Denso) Nozzles
- $357 shipped (ebay)
- 11176-27011 (6)
- Injector nozzle seat
- $16.32
- 90209-22006 (6)
- Injector washer
- $8.34
- 90201-08106
- Copper plate washer for injector nozzle (12)
- $8.16
- 22390-6A511
- Fuel cut solenoid assy
- $108.42
- 23303-64010
- Fuel filter
- $40.63
- Shipping to US
- $45
- Timing Belt and associated parts (partsouq.com)
- 13568-19065
- $38.41
- Timing Belt (@98k kms the original timing belt was replaced according to sticker)
- 13505-17011
- $96.52
- Timing Belt Idler Pulley / Tensioner
- 90507-27003
- $4.97
- Idler Pulley / Tensioner Spring
- 16100-19235
- $107.27
- Water pump w gasket
- 11213-17010
- $11.26
- Cover gasket
- 90311-32020
- $5.33
- Oil pump seal
- 90311-58006
- $6.64
- Oil seal (belt cover) No. 1
- 90311-58007
- $7.68
- Oil seal (belt cover) No. 2
- 17115-17010
- $1.24
- Intake manifold gasket
- 16284-17010
- $4.44
- Turbo water hose
- 16572-17010
- $13.48
- Radiator outlet hose
- 16571-17010
- $11.82
- Radiator inlet hose
- 90916-03089
- $14.97
- Thermostat
- 16346-66020
- $2.38
- Thermostat gasket
- 16401-54750
- $12.83
- Radiator cap
- 90916-02452
- $33.87
- Fan / Alternator belt
- 17179-17010 (5)
- $3.93
- Intake manifold no. 2 gasket
- 17171-17010
- $3.93
- Intake manifold exhaust gasket
- 90210-08019 (3)
- $1.38
- washer
- 11328-17010
- $17.75
- Timing gear cover gasket
- 99332-11260
- $20.41
- AC belt (not in stock, ordered Bosch belt below)
- 19879-47665
- $6.47
- AC belt (Bosch)
- Shipping to US
- $68.70
- $13.85
- 13568-19065
- Delta Vehicle Systems - Dual Battery Electronics Mount Plate - https://www.deltavs.com/all-products/dual-battery-electronics-mount-plate
- Delta Vehicle Systems - FJ/FZJ80 Caster Correcting Front Radius Arms - $825.00
- Delta Vehicle Systems - FJ80/FZJ80 Panhard Lift Bracket - $250.00
- REDBACK 4X4 EXTREME DUTY - 4X4 PERFORMANCE EXHAUST TO SUIT TOYOTA LANDCRUISER 80 SERIES (1990 - 1997)
Brake upgrade- HDJ81 Brake Upgrade - With Part #s and Pics
- Upon further inspection, sounds like the post-92 MYs came with the larger calipers/rotors, but its a great upgrade thread nonetheless
- Dawes Devices MkII Boost Controller
- Auber Instruments EGT Gauge
- SYL-1813-MR round type
- Auber Instruments EGT Probe
- TC-KEGTS K type thermocouple
- Auber Instruments Boost Sensor
- Auber-303 3 bar diesel boost sensor
