NLXTACY
Wits' End
NOTE: This is a general use stand-in for the OEM SST 09843-18020 used for setting ignition timing, checking ABS, transmission and airbag diagnostics.
Get it here: http://absolute-wits-end.com/diagnostic-port-jumper-wire/
I know what you are thinking, "A fancy jumper wire? For the Diagnostics port? I just use a paperclip". I use to be the same way.
There are two incidents that occurred within the past three months that forced a rethink of the jumper wire:
1. Person A needs some help tuning their truck before a smog check. Truck needs to be at 3deg Ignition Timing before heading out. Person A puts in the paperclip and starts the truck. Assuming its in diagnostics mode we proceed to set timing. Can't get it set correctly. Turns out the paperclip wasn't in the terminal enough to make contact, it was off to one side. Try again.
2. Person B calls in a panic that their truck is driving like hell after being serviced. Pop the hood and eventually find that the paperclip was still in the diagnostic port. Person B had forgotten the paperclip was even there.
So why not prevent dumb mistakes like this? The Metri-Pack male terminals give you nice, positive engagement and the length of the cable, coupled with the bright red coating, lets you know its still there and needs to be removed. Simple and easy and no need to hunt for a paperclip. Of course we threw in a paperclip or two as part of our Fuse and Accessory Kit but thats because everyone should have a paperclip handy
