Gas tank to fill neck hose.....
Who has the metric gas tank to filler neck hose?
Mine has a crack and slowly drips gas.
I checked the usual FJ40 suppliers, but they don't have one. And the auto parts stores around me have either 2", which is too small, or 2-1/4", which is too large. Nothing in between. It looks like 2-1/8" might work, but I can't find any.
dont know where to get a stock one but my napa store is owned by a local so he let me roam the radiator hoses and i found 1 an cut it to fit good luck
Radiator hose? I thought it had to be specifically for fuel?
I use a radiator hose as a fuel filler hose on my auxiliary tank in my BJ40, so it gets filled with diesel. When I use the aux tank I fill it right to the cap. Sometimes it sits for a few weeks before I use the fuel in that tank. I have never had any problems. The hose is one of those corrugated universal fit types with the spring inside so you can bend it to fit almost any application.
McMaster Carr has 2.125" ID fuel hose with a bend radius of 6" on page 229. It say to order in 5' increments but you can order in any increment you want (say 2').
www.mcmaster.com
radiator hose will dry and crack after a few years but bfd, put another in.
better than hunting fuel hose. marine supply has the fuel hose you bwant but no bends in it.
x2 on mcmaster. that looks like the best way to go. you could also take a rad hose and coat it in something that would make the rubber resilient to the effects of fuel?
I know that mustang makes one that might fit. You could have napa check that out. try 1971 year. coupe.
