- Thread starter
- #41
Have you checked to see if the carpet (new by the PO as you said) is holding the pedal when things stick?
might be one thing that you haven't checked yet...
Yes, no carpet to speak of. This situation is so annoying.
Zack
Which two lines are you speaking of?yes that is exactly what i am talking about. check the vacuum lines going into the front of the carb and make sure they are in the right spot. if they get switched it can cause your problem. in my experience
Why?WOW!
If you have a 60 and haven't done this mod, get to it!
The stock return springs are very lightly loaded. They do not seem to wear out. I have only seen problems w/ ones that had obvious environmental problems i.e. they had been on fire or seriously rusted.I think the problem is that the stock springs that return the lever get worn out and do not return the linkage properly, so this would fix the problem.
The stock spring used on the AP arm in 1977-78 models. Dunno if it still available new, as they rarely fail and are often missing, since they are not really necessary. Not sure why the Cruiser gods chose to install that spring for a few years and then stopped. Nothing else in the linkage system appears to have changed in that timeframe.What spring would be the proper spring for that location?
I mean maybe the sticking point is not a problem in the linkage, but the throttle itself (ie, in the carburetor) that is sticking open and holding the accelerator down with it.
The throttle linkage is fixed. Pics to come.
