Can you locate and remove the immobilizer, then try to start it?
That ain't happenin'. The ability to do that would render the system useless.
The whole purpose of the system is to make the vehicle "immobile" without serious legitimate intervention.
Dan, is it not "insertable" into the system, or does it replace section of wiring harness or ECU?That ain't happenin'. The ability to do that would render the system useless.
As I understand from @Dave 2000 , there is no battery in the key, and it is required by law to have an immobilizer.
However, I'm sure you could unplug it and plug the factory harness back together to bypass it for "diagnostic purposes".....
On the free standing unit when unplugged, nothing happens as in the immobiliser is disabled or the vehicle becomes immobilized?In Some models the function is bundled inside the engine ECU. In this case the module is free-standing. If it is not connected there is an open circuit and nothing happens.
The vehicle is dead. The module is not there to facilitate communications.On the free standing unit when unplugged, nothing happens as in the immobiliser is disabled or the vehicle becomes immobilized?
My, admittedly limited, understanding of it is the default state for the engine ECM is to allow the engine to run, but ONLY if it receives a signal from the immobiliser ECU. That signal can be one of two: either the immobiliser likes the key, sends the command to run, OR, it doesn't like the key, sends the command to shut down.
My theory - and it is just that - is that, just maybe, while it's waiting for a yes or no from the immobiliser, the ECM is allowing my engine to run if the immobiliser ECU is a little slow making its decision, but then the immobiliser decides it hasn't recognised my (defective?) key and sends the shutdown command to the ECM.
Might be complete bollocks of course, if you guys understand that word!
That was my theory as well, having never seem this particular system before. On my GX470, I had a key cut that didn't contain a transponder and it would physically turn all the locks and the engine would crank but never even a hint of running, just like Dan said. But that one also had a flashing key icon that would let you know that the key wasn't recognized.
And maybe, as I suggested earlier, that your later systems are just a bit more sophisticated, and quick enough to read the key before you could even crank the motor, hence no life whatsoever with the wrong key?
| 01/1995-12/1997 | FZJ80R-GNPEKW | VX, EUR, RHD, 1FZFE, EFI, ATM, LUB |
So the particular part number for your stand alone 89780-60020 immobilizer ECU was apparently only used in:
I think @cruiserdan truck might be this one:
01/1995-12/1997 FZJ80R-GNPEKW VX, EUR, RHD, 1FZFE, EFI, ATM, LUB
2006 TOYOTA LAND CRUISER (FZJ80L-GNPRK)
STD GEN LHD 1FZFE EFI ATM 4FC LUB
That model uses 89870-60010.
Here is a comparison photo of the two. They seem to be almost the same part, including the specifications that are on them. Of course I have no idea if they work the same. The 60010 version was used from 1999-2006. Both versions and years of the trucks used the same identical coil and amplifier part numbers. The part numbers for the keys and EFI computers were different. Probably not very useful information, but interesting nonetheless.
Calling @Dave 2000 to the party for info about the immobilizer......
Bilt4me - great minds think alike! Reading through other threads on here about similar issues, it seemed to me that he may be the one who can shed more light on this, and I've already messaged him, so hopefully, with a nudge from yourself as well, he'll be along in due course to give his thoughts.
sbman has already proved to be a font of useful info, and already I know stuff I didn't know a few days ago, so hopefully, between us, we're heading towards a solution.
It occurred to me, after some of sbman's comments, to try something I hadn't tried before, and maybe the results do indeed point towards this being the immobiliser causing my issue. See what you guys think: I disconnected the battery and left it for long enough for everything to be cleared. Now my thinking was that, if it is the immobiliser, and this is essentially a computer - and a pretty old one at that - then, like other computers, it may need some time to 'boot up' after power is first applied. So, with the help of an assistant who was ready with the key at the ignition barrel, I connected the battery and immediately had my assistant insert the key and go straight to cranking. My theory was that, just maybe it would run for a bit longer under these circumstances, as the computers would be busy getting their acts together as they had only just been powered up. And guess what? It ran for about five seconds, which is a couple of seconds longer than it's ran for since this problem appeared. To be sure this wasn't a fluke, I went through the same procedure three times in total, and every time, it fired immediately and ran for around five seconds each time.
Now bearing in mind that previously, attempts to start it, even the first attempt of the day (but when the battery was already connected) have often resulted in it not firing at all, and when it would randomly start, it was never for more than about three seconds. So, does this support the immobiliser theory? I can't think of any other reason why it would run for a little longer than normal if it's started the instant the battery is connected, unless there is some truth in my aforementioned theory.
Discuss...
And to clarify an earlier post - I tested my MAF as per the FSM, and all tested within spec. as far as I could establish. The FSM doesn't say what voltage should be produced by the MAF as air flows through it - it simply says the voltage should fluctuate, and mine did - from 0.6V static through 1.3V cranking and up to 2V at idle when it ran briefly. I did suspect the MAF from an early stage in this process, but ruled it out once it tested OK.
NEWS FLASH!
OK, the result of my latest test:
I just disconnected the 89780-60010 ECU in our Autana. The engine started and ran "normally" for about 5-6 seconds and then shut down like the key was turned off.
So, disconnecting the airflow meter = starts and runs for 1-2 seconds and disconnecting the immobilizer ECU = starts and runs for 5-6 seconds.
This comparison suggests the problem is in the immobilizer system.
It also confirms that an earlier immobilizer-equipped vehicle will actually start (at least the type that uses a free-standing ECU) where the later ones only crank.
I am gathering Paul that your car does not start/run/cut and the start/run/cut consistently ? That is it might or might not but when it does it is for a short period of time?
I assume you have checked the fuel supply etc.
You could pull a plug lead and lay it NEAR an earthed area, and have someone crank the engine and watch for the spark, if the spark stops and the engine dies forget the fuel side of it. When the MAF is out, car would normally start/run/cut and repeat. ECU relearning is only after battery disconnect and not MAF disconnect.
regards
Dave
