Hey. Thinking if getting a Ron Davis for my 80. I am confused by the pic for the radiator I found on his site that will fit an 80. It does not show all the connectors. Does the one you bought match your stock radiator as far as where fluid enters and exits the radiator, mounting holes, etc?Ron Davis Radiator for the win.
I’ve been running mine for several months now. I am very happy with it.
I spent a good amount of time last nite reading radiator threads. I could not find what i was looking fore. I like to know before and after temps with said radiators.There has probably been 30 threads on that in the past month. Try a Koyorad.
Could you please post some real world numbers on Eng temps is severe conditions.Ron Davis Radiator for the win.
My system works perfect in normal driving conditions. I would like to be able to drive up Thompson Hill without worrying about it overheating.Go oem and never look back. Find it online and save 30 percent.
Are you running aluminum or copperGo oem and never look back. Find it online and save 30 percent.
TRAD aluminum. Copper absorbs heat more rapidly but AL gives up heat quicker. I ran a CSF copper core radiator for 2.5 years. It’s a well built unit but, as many have reported, it can’t cope when the going gets tough.Are you running aluminum or copper
I was running my AC on our last trip but had to turn it off a few times when Eng temps reached 210 - 215.
If a Hi performance aftermarket radiator would fix that I would be interested.![]()
In all honesty My 80 is a street legal trail Reg, Thompson hill is the hardest part of The Dusy Ershim trail. low speed relentless rock crawling.Curious, what RPM‘s and loads are you running at? The harder the hill the cooler I run, because I keep my load down and RPM’s up, usually in the high 180’s to low 190’s F. I will run 3,900k in 2nd/high range, or for extreme example, 2 weeks ago I had to use low range, same RPM’s but only 29mph lol. Was a big ass climb, and I still have stock gears.... (stock radiator/blue hub-20k(?) fluid)
When it starts to get hot in those conditions I put in neutral and bum it up to around 1800 RPMs and the temps start drop immediately back to normal.
I running a modified blue hub and the cooling system is all new oem except the Koyorad.![]()
Just like post #3 it's nice that jjdeneen918 is happy with his Ron Davis but I would like to hear some real world numbers. Like when it's 100+ out side in stop and go traffic with the AC on what are the Eng temps running.
I'll give you the numbers I have from a '94 purchased with 277k and the original brass radiator. Temp readings are from a Toyocom, stock fan and coolant wass Prestone green.
1st readings (average) from November - January in Las Vegas
Highway speeds (65-70mph) and no AC: 186F (max 187F)
City driving and no AC: 191F (Max 194F)
That radiator cracked while offroading in January 2020 and I installed a Koyorad A1918. Coolant was Prestone green
2nd readings started in June when it regularly gets well over 100F in Las Vegas
Highway speeds with AC: 194F (Max 196F)
City driving with AC: 199F (Max 206F)
Idling with AC: Max 212F
The Koyorad only lasted until July. I slugged the motor going up an off-road mountain pass and blew the top (I know, I should have been in a lower gear...). This time, I went back and purchased a used original brass radiator (cash was tight) and used Peak Final Charge Global Extended Life red coolant after flushing the system with distilled water.
3rd set of readings from June-August in and around Las Vegas
City driving with AC: 196F (Max 204F)
Personally, I didn't see a significant performance difference between the stock brass radiator and the A1918, and I know that I said that the brass radiator was better than the Koyorad, but that's because the original brass radiator lasted the PO and myself nearly 280k miles before it crapped out. Until someone says their koyorad has lasted for about that long, the OEM has the edge despite new ones being about double the price. Still, I wouldn't hesitate to pick up a Koyorad. Just don't overtax the motor like I did and I think you'll be fine.
