Please see attached images. Are these fusible links - the 3 small wires between the green and creme connections? I have not been able to find clear info on fusible links. I'm no electrician nor mechanic so this is new. My problem is that when I attempt to install the new battery, the cable starts to spark when it hits the terminal. Everything is turned off and the I'm putting them on the in the right order. Starter is good.
One of the fusible links is fried as you can see in the image. Would this be causing my problem? Where can I get replacements? How do I replace them? Is there anything else I should check for?
This is for a 1985 US FJ60
Thanks so much.
Thanks so much.
