I'm finally diggin in a bit more to troubleshoot. Thanks @jonheld. Your fusible link test worked and I confirmed all three intact.
Instead of a visual test, I pulled out my voltmeter and tested each one of the fuses...they are all good. (thanks @Dave 2000 @BillyGoatMTB); but I'll be honest, I didn't know how to test the EFI MAIN relay under the hood.
Then I did a voltage test of the fuse boards. Under the hood, power is going to the circuits, but only 10.4V which is low. I then checked the end-point for the stereo wiring harness that I'm trying to install, nothing. So I checked the instrument panel fuse block. I started with CIG, TAIL, OBD, STOP, DEFOG and couldn't find voltage. My wipers barely worked. And when I did a voltage check, the voltage was around 3V, super low. I finally checked my 2-week old battery and it was only around 11V, so took it back to the store to get recharged, tested, and will pick it up again tomorrow.
So the trouble seems to be between my hood fuse box and instrument panel fuse box?
I have the EWD but didn't really read it till today. I am trying to track the issue from my fuse block to my radio which is why I started pulling and testing the various instrument panel fuse circuits since they are primary with the radio. Here's a copy of the EWD I found online for free:
Another friend suggested that maybe my ECU could be fried from the fusible link being severed which may explain the O2 sensor problems on my OBD? He also recommended to check my chassis grounds for good contact by removing cleaning and reattaching.
I'll pick up my battery again tomorrow afternoon and will start troubleshooting again. Any suggestions? A reminder that my entire interior is stripped down and most of the electrical is disconnected. Hopefully, this isn't the reason for some of my issues. I'm still baffled that when I rigged my severed blue fusible link briefly to see if that was the issue, my new radio worked great...and now nothing. I feel I must have blown something?
Thanks again for all of the help, advice, and suggestions!
