So I have been doing some research about using premium fuel vs regular fuel in my 2018 LC 200. Im not convinced I need go spend the extra $ fot premium. Will someone, please, explain why I need burn 91+ Obtain vs 87. Thanks
It’s been my personal experience with my 08’ that it seems to make no difference in my own mpg. I don’t tow, and I drive a bit like a grandma most of the time. Ethanol free premium, which is available at about half of our stations up here in Montana seems to make a noticeable improvement in mpg. But then you have to justify the additional cost, upwards of another $1 per gallon! And if I had a supercharger, I would only run premium, but otherwise I’m happy with regular. And I know some places in the country have an even lower octane fuel, or some say a lower quality octaneSo I have been doing some research about using premium fuel vs regular fuel in my 2018 LC 200. Im not convinced I need go spend the extra $ fot premium. Will someone, please, explain why I need burn 91+ Obtain vs 87. Thanks
Well put, other than the thread with learned ignition adjustments being what I’d call fact.. but to my knowledge no one has compared the same values in LC vs LX with their supposed different octane “requirements.”Covered here exhaustively. Mostly opinion with no facts - particularly when it comes to Lexus/Toyota engine tuning. I run regular in my 5 Toyota V8s. 2 of which are LX570s.
As you have an LC, the answer is straightforward. The manual tells you the requirement. 87 octane is all that is necessary for safe and optimum performance. While it's possible 91 may give a slight edge, there's no requirement for it.
The LX is a whole different story and shouldn't be mixed into this discussion.
If you use just the word octane in a search on the 200 section of Mud, you get 800 posts. And if you did more complex searches with premium fuel, or etc. as search terms, you’d probably get way more than 1K posts. If yours is a real question, maybe some more research would help?So I have been doing some research about using premium fuel vs regular fuel in my 2018 LC 200. Im not convinced I need go spend the extra $ fot premium. Will someone, please, explain why I need burn 91+ Obtain vs 87. Thanks
I like my popcorn with butter and saltCovered here exhaustively. Mostly opinion with no facts - particularly when it comes to Lexus/Toyota engine tuning. I run regular in my 5 Toyota V8s. 2 of which are LX570s.
