Fuel filter in 40 minutes like a boss
Getting the filter off...is not a big problem. Getting the banjo bolt (toward the rear) started without dropping one of the new crush washers isn't so easy. Once you get everything started, yes....you can manage to tighten all the bolts.
When you put the banjo on, put the first gasket in, push the bolt through, put the 2nd gasket in, then push everything tight to the filter and thread it.
I used Toyota filter was 38 bucks from Toyota here grand junction
mine has 165K on it. At what mileage would one consider replacing the fuel filter? I'm one of those who prefers to do PM at personal convenience (in other words before things to go kaput). However, I don't like doing stuff unnecessarily prematurely either;)
It is really one of those things that isn't 'mileage' dependent. You could get a 'bad' tank of gas in just ONE fill-up under the right circumstances (old tanks, tanker dumping fuel in a low tank, you filling up at the same time).
No Kidding!
Yes, thank you....I know the procedure, its just hard to reach the rear one and get the bolt started. If the banjo fitting has been moved at all (its a rigid fitting, and mine was) then the bolt wants to cross thread or not start at all. You have to let the filter almost 'dangle' in order to get the bolt started and that is when the crush washer closest to the filter falls off and into the nether-regions.
I have 163k on mine and have changed it three times...
The original owner had it replaced at 70,000. Best I can tell it now has 110,000 on that filter. With a few long trips in the very near future I will be changing mine over the weekend. Thanks for the tips.
Thanks so much for posting this writeup, it is super helpful!
I just finished doing my fuel filter and it took less than an hour all told. Long, skinny arms are a definite benefit when doing this job! Used long socket extension, flex joint, 6 point socket for the 12mm bolts and a flex head gear wrench for the 17mm banjos. Cracked the banjos loose before loosening the mounting bolts, I think that helped a bit.
Tried very hard not to move the rear banjo at all when removing the old filter and the new one went right in and the banjo bolt threaded in with minimal fiddling. Slotted the rear mount to make the install a little easier, not sure it made much difference.
The old filter had apparently been replaced before, it was marked 'made in Israel'.:meh:
Tips for fuel filter
Open gas cap
1 slot the new filter for easy installation
2 . 24 inch extension 3/8 drive 6 point swivel socket 12mm
3. 17 mm socket for fuel lines use 6 point only
Go up from underneath for the filter bolts
I did both fuel lines with stubby 17 mm through top of engine bust loose then turned out by hand on both sides
You can also reach the back fuel line bango bolt thru the bottom
Hope this helps somebody!
I did mine in 2 minutes, had to fill it with diesel before screwing it back on :eek:
