Front Sway Bar Fastener Question (chasing a metallic popping noise) (6 Viewers)
LA
Hi folks,
I went and did a little wheeling this past weekend, and while going over some ruts downhill (slowly, but fairly deep), I slid down the hill a bit into a rut, and the truck came down a little hard (dirt, not rocks). I heard a popping noise like metal on metal when it happened. Got off the hill fine, drove home, but noticed that when turning left or right, slowly, like into a driveway, with a slight incline, I hear a similar pop. I'm about 80% sure it's coming from the front of the truck, not sure about driver/passenger side.
So I spent some time crawling around under it, making sure things were tight, etc. as one does. I noticed that the front sway bar bushings (see pic) have two fasteners (duh). However, one is going what I think is the wrong way, and there is no nut. To me, this seems like it could be the source of my problem, however, these sway bar bushings were replaced by a shop about a year ago (normally I do the work myself, but I wanted these done before a trip and they were doing my t-belt anyway), and I have not heard this noise before the event after my wheeling adventure.
Question: I assume these fasteners are installed wrong. It's the same on the left and right. Looking at the partsouq diagram, I don't see any nuts, so I assume the shop put them in the wrong direction, threading them thru a captive nut on the backside or something, leaving the clamp for the sway bar bolted effectively on just one side. Can anyone confirm, or send me a picture of theirs?
Thank you! Ok… so those are actually correct.
In that case, any other ideas on where the noise could be coming from?
210k on the truck, in the last 6 months, I’ve replaced front UCAs, front shocks, rear UCA/LCA. All with OEM. About a year ago, I replaced the front/rear sway bar end links and rear bushings, the shop I mentioned earlier did the front bushings.
Sorry I can't help since you replaced the rear sway bar bushings and end links already, but for someone else reading with a similar problem, I had a light metallic jangling sound on low speed turns and bumps around the neighborhood, solved it by replacing the worn rear sway bar cushions/bushings (and replaced the end links, although it wasn't necessary in hindsight). The bushings/cushions on the end links were very worn/flattened and there was a lot of play where the end links connected to the bracket.
There should be a nut on the bottom of that downward-facing bolt.
Clicking while turning is typically a symptom of CV axles wearing out. Front-end noises can be tough to pinpoint. You basically have to go through every bolt, nut and ball joint and find what's loose/moving.
Thanks. I also replaced the CVs with OEM just a couple months ago, so not those. And I'm not clicking. This noise is definitely something slipping just enough to suddenly thwack into something adjacent. I've gotten to where I can reproduce it by taking a turn at speed, or taking a turn into an incline like a driveway. I'll continue probing around under the truck this weekend.
Also, I thought the downward facing bolt needed a nut too, but it turns out the bracket is threaded on that side, so no nut required (see shop manual image posted above). Furthermore, I replaced the sway bar bushings and end links long before this issue appeared after my wheeling adventure last weekend.
I know the image from the FSM shows no nut, but mine (original OEM) has a nut on it...
Other potential/likely areas for that type of noise would be: ball joints, tie rods, shocks, LCA bushings/bolts.
Hi folks,
My 2006 that I replaced original parts on with new Toyota parts looks exactly as yours. It looks exactly as the diagram posted. There should not be a nut, the bracket is threaded.
Yep. I just rebuild the front end and had a nasty clunk after. I tore the entire front end back apart and it still was happening.
Puzzled, I then realized I never fully torqued down the sway bar link on the LCA. OE ft.lbs and clunk was gone.
Oh Interesting… i thought i was the only one.. lol. I also have a metallic “clunk” sound at slow movements in parking lot or driveways with the steering turned either direction, and it only happens once each time… (if i continue rolling, it doesnt happen again). Happens on flat ground too. Flex is not part of the equation.
Front Axles and LCA were replaced, new OE about 5k miles ago. Same with front sway bushings and extended TT end links. SPC UCA has a bushing w/ slight play, but not enough to clunk
Drives perfectly fine otherwise… and i keep forgetting to chase it down, but looks like I’ll inspect the sway bar setup again.
Anyone else who had this issue but resolved?
Check your UCA cam bolt torque. Mine were also loose after alignment as the dealer tech didn’t torque them properly
I’m going to double check all the stuff I did is torqued this weekend. I did them myself, so I’m reasonably sure I torqued everything, but I am known to break things occasionally…
Just got done going through all the suspension components I've swapped, and re-torquing them to the appropriate value.
- front UCAs
- sway bar bushings and end links
- rear UCA (these were not torqued properly, I think I forgot to re-torque them after putting the truck back on the ground)
- rear LCA (same with these)
- rear sway bar bushings and end links
I haven't yet tried to reproduce the sound, but I'll report back when I get a chance to test.
I also went and looked for anything else loose, triple checked the skid plate fasteners were all tight, and generally just banged around on things with a fist to listen for rattles. Was not able to find any other loose bolts or anything else rattling.
I'm declaring victory (for now...). I've just done a test drive, and for one thing, any rattle while going over bumps is gone, once again (this is how it felt on my test drive after doing all the suspension work). I can no longer reproduce the thwack that caused me to start this thread. I think the thing that fixed it was retorquing the rear UCA/LCA, as they were quite loose.
Lesson learned. Always (RTFM and) retorque your suspension bits with the truck on the ground after replacing parts! I must have really lodged some stuff around and caused the fasteners to loosen up on my offroading exercise.
