Ok heres the deal.... I had a little bit of wandering issue, and my TRE's were old warn and getting a little sloppy, so I swapped all 4 out for Moog 555's set to FSM length and took it to my local tire shop to get the toe set. I have been really busy, and didnt think much of it for the last month or so, but got to doing some sunday maintenance and noticed it was eating the right front tire FAST but went straight down the road. Took it back and they set the toe again and they rotated the tires for me. In less than 100 miles I had very noticeable heal/toe wear on that right front again on a evenly worn just up from the rear and a good drift to the right.
So I took it the place that does nothing but alignments, and they tell me the toe was out by a 1/4 inch and that they took care of it and it should not pull anymore or wear things much. Still "feels" like something is a-miss in the front end with this alignment and tire noise seems to still be "more noticeable" than before any of this. Though this toe setting is better than the last it seems.
I just rebuilt the front knuckles with all new stuff last fall (8k miles ago) and the tire eating only has started AFTER new TRE's. Steering arm nuts are still tight, trunion cap bolts are still tight I am sitting on OME 61/62 with 30mm spacers in the front and tires are only 5k old (255/80/17). I did just have to reset my drivers side wheel bearing preload yesterday and I just checked them 7-8 days ago. Did notice that my actual tie rod does not have even thread showing from pass to driver side anymore even though thats the way I set them
Am I missing something here, I inspected my FCA bushes and pan hard bushes and from what I can see they look fine, a little dry but no visible cracking or dry rot that I can see with out disassembly anyway.
Edit: Is it really necessary to pull the pitman arm and dampener to swap out tre's on the draglink??? I just swapped the ends and that was that and reconnected the steering stabilizer last . Never touched the steering wheel or anything while the drag link was out.
