Hey guys it's been awhile. Read everyday but have learned enough to not ask stupid questions and figure things out for myself, for the most part. BUT I'd like to run something by yall if you would be so gracious.
Taking a fairly regular trip tomorrow- couple hundred miles each way. About 2k ago I tackled the knuckles including spindles, bearings, axle flip, just about everything. Tonight I put the truck (91) up on stands to ensure all of the bolts were still tight related to the knuckle build, checked the caliper bolts, just about anything up there that could have loosened up, or is regularly suspect to loosening. Everything's tight. However, my front axle seems to have a lot of movement as it relates to the front drive shaft. Basically, I can move the front wheel/hub, in this case the ps wheel, while on a stand, with all other wheels down, a good bit before the front driveshaft even moves itself. Probably an inch of rotation if measure on top of a 33" tire. So were talking left to right rotational movement. I don't know what sort of play might be acceptable there. Anybody have an idea if that's normal play? It just seems like a lot.
Thank you everyone.
Thank you everyone.
