About 6 weeks ago, I did a front axle/birf rebuild on my 96 LC with 196,000 miles on it. Things looked surprisingly good inside, original inner seals not leaking. The job went smoothly as I took it nice and slow. Getting to the point, now my newlt installed OEM inner seal on the passenger side is leaking. I feel like I did everything right when installing the new seal: checked for burrs, made sure spring stayed in place, used the proper install tool(and diff breather tube is functioning btw). The drive axle slid back in and splines engaged effortlessly. So...my question is, when I go back in(sigh...) to replace the seal(again) what do I need to do/check for that I am missing so as to avoid the leaking? I am going with another OEM seal as it seems most prefer this on the 80's unless someone convinces me otherwise. Would very much appreciate you guy's help!
Chris
Chris
