For Sale Fresno, CA: 1994 Toyota FZJ80 Land Cruiser
Year
1994
  1. 80 Series
Fresno, California United States
Mileage
197550
Color
rgb(6, 33, 16)
1994 Toyota Land Cruiser with 197,550 miles. Triple locked. Overall the Cruiser is in good shape and it drives well. I have recently done a lot of work to the vehicle including the following: hood lift struts, rear hatch struts, new tie rods, steering dampener, all new seals, gaskets and trunnion bearings on the front axle, new fluids throughout (front and rear diff, transfer case, transmission, engine oil and power steering fluid), new spark plugs, new battery, new air duct hose, new air filter, new timing chain tensioner, new power steering o-ring and gasket, new vacuum hoses and some evaporation hoses, resealed the upper and lower oil pan and replaced all six connecting rod bearings. The reason for replacing the rod bearings is the engine has a ticking/knocking noise. According to the pervious owner it’s made the noise for over 30,000 miles. After replacing the bearings the noise is still present, but not as pronounced. When the vehicle is driving down the highway the noise goes away. The engine doesn’t use any oil, has good power and compression. The throttle body was removed and cleaned, valve clearances checked and a new valve cover gasket was installed. The majority of the parts used were from Toyota. I also have a bag of new vacuum hoses and seals I planned on changing but I haven't gotten around to yet. Tires are in good shape with lots of tread and a matching spare. I have a pile of service records from the two previous owners. The engine received a new head gasket from Toyota at 156,109 miles. Triple locked and all lockers engage. I took it up Bald Mountain earlier this week; it performed well and made it up with ease. The previous owner had the roof, back hatch and fender flares painted black. The back hatch has a couple spots of surface rust. I included pictures of the underside. ABS does not work, the previous owner removed the ABS fuse because of an issue and I haven’t gotten to figuring out what needs to be fixed. Driver leather seat is in poor condition, passenger seat is okay, and the rest of the seats are in good shape. The vehicle has been in one minor accident. I replaced the front bumper and condenser. Included is a picture of the Cruiser before I replaced the bumper. Clean CA title and it passed smog this month. Let me know if you have any questions. Asking $11,500
