- Thread starter
- #121
Thanks, Lated. I like the quote in your signature line. So true.
Here are some pictures of the removal of the axles. This actually happened before installing most of the wiring but it seems to be easier to follow or share an idea when posting by system.
I don't have the luxury of a lift, so jack stands had to do. There's a trade off between height and stability. When removing leaf spring pins from a 25 year old vehicle, you have to hammer on them pretty hard. It can get a little scary seeing the truck sway on the stands while underneath it so I make a point of placing tires or additional blocks under the frame so if it does fall it might not squish me completely. FYI - most jack stands are rated as a pair. So a 4,000 lb stand is really only good for 2,000 lbs.
The rear axle's shackle pins came out without an argument but the forward pins were rust-fused to the OEM rubber bushings and refused to budge. I had to use a propane torch to burn/melt them enough to extract the pin.
