kiwidog
Kiwidog
Had to make a little room in the shop after pulling the axles off the frame. Getting ready to overhaul the front and the rear complete. These are out of the '78 and have 3.7 gears so it will be more of a highway queen.
Wanted to move the '78 frame out as the frame from the '76 is in better shape and have already started on the rear cross member.
Used the snow plough on the '80 to move the frame out of the way.
Yes you can lift the axles up onto a bench for teardown and overhaul. One end at a time. Pretty heavy but if an old fart like me can do it, you young guys will have no trouble. Tie the first end down just to be safe before lifting the other end.
A $15 tie rod removal tool saves a lot of work taking the steering joints( tie rod ends) apart.
There are seven counting the stabilizer.
Here are a few pictures
Thanks jb
Thanks jb
