??? I have front differential whine (not grind) upon acceleration through first and second gear. I don't have any distinguishable noise upon deceleration. Some background/history: 223k, regular changes of diff fluid (every 15K), no evidence of contamination or axle seal failure, fresh fluid in now, some slop in drivetrain, ujoints and other components are good to go.
I did have the front pinion seal leak, but I got to it before it allowed for any damage and the pinion bearing was ok at the time (about 6 mos ago). I am about to do a full birf job and would like to get this while I have the front end apart, clean and drained.
Question is: is the noise more likely to be R&P related or pinion bearing related? I always thought that acceleration noise is R&P? I won't know for sure until I open it up. I need some help on this because I don't have alot of options locally for quality diff rebuilds, can't afford to regear right now, want lockers too and can't have the truck down for an extended period (work related). I don't NEED to regear yet because I'm still pretty much stock and will be for a while.
Any one have any experience with purchasing a built 3rd ( aftermarket or OEM replacement) and dropping it in? If so, who can you recommend (in addition to Slee, Randy's R&P)?
Thanks for any and all help suggestions.
