fjz80 Coolant leak around bypass pipe (2 Viewers)
Glad you found it.
Agree with stuffing something in the crack from both sides, maybe like a Marine grade epoxy, smoothed off on the inside so as not to interfere with the O-rings or the pipe, will likely last years.
The crack would likely benefit from a good cleaning before using the epoxy, maybe a brass "toothbrush" would help along with some supercleaners to remove any build-up of crud??
That's my leading plan. I just cannot justify removing the head to get that off.
The timing chain cover can come off without pulling the head ;)
It can, but it appears that its worse than pulling the head.
That said, I have resolved my issue. I welded the crack. Well, my wallet welded the crack
I want to see pics. Did you remove the cover of have it welded in place?
That was a feat if someone welded that in place.
YOU MUST SHARE! ;)
YOU MUST SHARE! ;)
Welded it in the vehicle, here is a picture of it welded and smoothed out. And yes, i knew it would require a very good tig welder.
This provides hope and help to the next guy this will happen to.
Thanks for posting info about it.
