I had the sunroof leak problem that no one could seem to find either - replaced the glass, seals, cleaned the drains to no avail. After three months and about 40 hours of investigation by the local toyota dealer, we (and I say we because the dealer's initial answer was that I should just get the interior detailed regularly and live with the leak until I did a bit of agressive negotiating...) figured out that the screws that hold down the track were the cause. They yanked the track, put some goop on the screws, put everything back together and the leak went away...for nowI Have A 1994 Fj80 With A Leaky Sunroof. Only Leaks On One Side Unfortiontly It Is On The Drivers Side Right Above My Head. Drains Are Clear! Seems To Be Leaking Underneath The Track Maybe??? Any Answers?
The sunroof does sit flush and all the drains are clear as can be. Can you buy just the sunroof glass seal? I went to the Toyota dealer and they could not seem to find it! Thanks for the quick reply.
yes they do.
i found the reason for mine leaking was the rear drain tubes were kinked when someone installed some aftermarket s***.
they ran wiring to the back pulled the panels and in the process of doing so kinked the tubes so they wouldn't drain.
i don't use my dope smokers retractable roof window so i sealed mine.....redneck as hell but doesn't leak
