Gasket P/N 90430-43002
Water Gasket P/N 16341-61030
4 bolts on housing P/N 91611-B0845
You do not need to drain entire coolant from truck. About 2 liters drops out from the top radiator hose when removed.
Order the 4 bolts! I can’t stress this enough. I took a risk knowing mine had been done 12 years ago by previous owner and I was concerned at their condition when I removed them.
I used special rtv for sensors and coolant related components but others have gotten away without. I used anti-seize on all bolts installed. All bolts were brass wire wheeled completely clean before re-install.
