I have been a bit disorganized when it comes to my new project, and with there being multiple threads, with sporadic information, I wanted to organize all of the information into a single thread so I can keep track better....and hopefully also help others. I will also try to give credit to those companies and list members that I have "bugged" over the years, and in the future TIA.
I have spent countless hours reading threads and taking notes on all of the IMPRESSIVE BUILDS on this site. I have kept a log book with all of the ideas, and all of the dreams that I would like to incorporate into my build. I have been saving for a few years and have been fortunate enough to stash away a healthy budget for my build. I am not unrealistic in the amount of work that I have laid out. Since I am not under any time restraints, this could take a while; just warning the list that you may be following this thread for awhile
HISTORY: (brief) I owned an '84 FJ60 years ago, which burned up in a fire while wheeling.....
Fast forward, and I determined that I really liked that truck, and I wanted to get another one; so what does any sane Cruiserhead do, I ended up buying 7x of them over the past few years
After keeping the "best" of the bunch, and selling of the rest; I now have 1x FJ60 and 2x FJ62's.
Again, completely "sane" right?
GOAL: 1x completed resto/mod/upgrade/semi-Expo/semi-camp edition FJ6.TBD
With the leftover parts, I will build a 2nd FJ62. 100% OEM vehicle, Red with Grey Interior.
Below I will layout my General Plan, and will update along the way when/if things change. Currently the below parts have been purchased and are either en route, or sitting on the BUILD SHELF
BODYWORK:
The FJ62 that I have decided to use as the base to my build was originally from Texas, and the frame is in very good shape. The body is original and is not covered in filler. There is rust in the rear dog leg and rear 1/4 as you would imagine. I have purchased multiple sets of replacement panels, and had them shipped over from Germany (it was cheaper to get 5x sets than just the single set I needed; therefore, the remaining unused will be for sale). I have also purchased the Wolf Steel Restoration Panels as well
001117 WUSTENTAUGLICH.DE Radlauf HJ6 - 5x Sets (let me know if you need one)
TLC5L2 WOLF STEEL Rear quarter panel repair including dog leg 1980-89
TLC5R2 WOLF STEEL Rear quarter panel repair including dog leg 1980-89
After bodywork has been completed, the truck will receive a complete respray: Color TBD
Interior will get Lizard Skin or equivalent, and then Dynamat
Undercarriage will be sprayed with Line X or equivalent
FRAME:
Sandblasted
Reinforced welded if necessary
Powder coated: satin black
AXLES:
Removed and rebuilt tip to tip
Powder coated: wrinkle black
SUSPENSION:
OME Medium Currently Installed
BRAKES:
FRONT: Wanted to upgrade to a better disc, but after reading I am not entirely convinced that the OEM FJ62 setup can be improved. Was going to purchase new parts all around and rebuild to stock specs. Unless otherwise am convinced of better.
REAR: wanted a rear disc, but after reading I am not entirely convinced that there is a good solid solution. Plan to rebuild/replace OEM rears. Unless otherwise am convinced of better.
MOTOR:
40k mile 5.3 Vortec
520-8501-5 JEGS HOOKER LS Cast Iron manifolds, Gray ceramic coat
868-8900 JEGS Stage 8 8900 Series Locking Header Bolts
760-66032 JEGS Alum exhaust gaskets
809-19212593 JEGS LS Muscle Car Oil Pan Kit: pan/tray/dipstick
154694 ROCKAUTO AC Delco Fan Clutch
1580692 ROCKAUTO AC Delco Fan Blade
Thanks to @FJ60Cam for answering all my PMs
ECU/WIRING:
I will be doing the ECU programming and using the OEM GM wiring harness to adapt to my FJ62
DBW Pedal
AC: Yes
Cruise: Hope so !?!
COOLING:
Aluminum Radiator
Trans Cooler
PS Cooler
Oil Cooler
MISC ENGINE:
TRANSMISSION:
4L60e Automatic Transmission
625-COS64L60EBM Lokar 16" shifter for cable
TRANSFER:
OEM split with rebuild kit
Supplied by @orangefj45
ADAPTERS:
Downey (does that tell you how long I have been collecting parts)
Advanced Adapters
DIFFERENTIAL/OBA:
ARB Locker Front
ARB Locker Rear
Extremeaire Magnum
-misc relay/breaker/manifold/fittings
All parts spec'd and supplied by @orangefj45
WHEELS/TIRES:
12-670604 SUMMIT RACING Wheel Vintiques Series 12 16x7
The Tire Rack 4x BFG Mud-Terrain TA KM2 in LT255.85R16
Thanks to @scrapdaddy for answering all my questions
DUAL BATTERY SETUP:
TBD
FRONT BUMPER:
RLC WELDING AND FAB Local to me
FRONT BUMPER WINCH:
WARN ZEON Platinum 12: have not completed my research on this yet
REAR BUMPER:
REAR WINCH:
TBD
LIGHTING:
Grille and Lighting Swap to FJ60 Rounds
Upgrade to LED/HID/???
INTERIOR:
Convert from electric to manual windows (less to break)
Carpet/Seats: This seems so far in the future, that I have not even begun to dream
GAUGES:
Speedhut Gauges 5-1/2" Legends - Renegade - 4 in 1 Cluster
If anyone sees flaws or would like to challenge some of my ideas, please feel free to do so. I am fairly educated, but don't claim to know everything. I would also like to be upfront and say that I am building this FJ62 to be fun and well-equipped to do many things. I will probably NEVER go extreme-wheeling, or spend time trying to climb a pile of rocks , but I do plan to drive this once I am finished; I would like to take it camping, and some Expedition type of trips. Some of the things that I will do will 100% be considered overkill.....but I will be doing them anyways. I am located in Louisville, KY so if anyone is ever passing through, or would ever like to stop by and talk about things...I would try to make myself available.
Chris
C2
BODYWORK:
FRAME:
Sandblasted
AXLES:
SUSPENSION:
BRAKES:
MOTOR:
40k mile 5.3 Vortec
ECU/WIRING:
DBW Pedal
AC: Yes
Cruise: Hope so !?!
COOLING:
Aluminum Radiator
Trans Cooler
PS Cooler
Oil Cooler
MISC ENGINE:
TRANSMISSION:
TRANSFER:
ADAPTERS:
Advanced Adapters
DIFFERENTIAL/OBA:
ARB Locker Front
ARB Locker Rear
Extremeaire Magnum
WHEELS/TIRES:
DUAL BATTERY SETUP:
TBD
FRONT BUMPER:
FRONT BUMPER WINCH:
REAR BUMPER:
REAR WINCH:
TBD
LIGHTING:
INTERIOR:
GAUGES:
Chris
C2
