Parting Out FJ62 (Red) in MS (UPDATED 10-22-18)
dnp
Supporting Vendor
Jackson, MS
UPDATED 10/22/2018
STILL HAVE PARTS - LET ME KNOW WHAT YOU NEED
PLEASE PM QUESTIONS / REQUESTS ONLY! (For some reason, the forum software doesn't always notify me of new posts)
I'm parting out a red 1988 FJ62 in MS. I've sold some of the larger parts (doors / fenders), but here is a fairly complete list of parts I have left (with prices) If you don't see what you're needing on the list, check with me, as I might still have it and forgot to put it on the list. PMing me is usually the quickest way for me to respond, as sometimes the MUD thread software doesn't notify me of a recent response to this thread.
($15 minimum order - it's just hardly worth the effort to ship for less than that)
All prices are PLUS shipping
3FE bare block $50 SOLD
Steering gearbox $150 SOLD
Female portions of rear seat belts $15 Each
Headlight buckets $25 each
Distributor - complete with cap $100
Oil sending unit $15
Oil filter adapter $25
Radiator fan shroud $50
AC compressor $65
Alternator (tested as “good”) $75
Power steering pump SOLD
Power steering cooler lines $50
Steering wheel $60
Dash pad with one very small crack and one nick $50 SOLD
Front heater assembly (core and housing) $50
A/C and heater dash controls $20
Various switches, ask for it and I'll look $10 each
Heat and A/C ventilation hoses (ask)
Blower motor $20
Rear heater assembly $40
Steering column WITH key $75
Speedometer cable $25
Quad gauge $40 SOLD
Tach $30
Main whole-truck wiring harness (behind dash/through the firewall on both sides/main harness running down the driver's side to the rear of the truck) $90 SOLD
Rear washer bag and motor $25
Front wiper motor $30
Transmission with t-case $625 SOLD
Block to transmission adapter (OEM) $50
Trans shifter $50 SOLD
T-case shifter with boot $30 SOLD
Transmission metal lines (trans. to radiator) $25
Rear driveshaft $75
Front driveshaft $75 SOLD
Rear axle complete hub to hub $250 SOLD
Front axle complete (including Aisin hubs) $350 ($275 without hubs) SOLD
Rust-free roof $150 SOLD (with cowl)
OEM springs (front and rear) $125 for all 4
Coil/igniter $75 SOLD
Oil cooler $50 SOLD
Passenger side front seat belt $40 SOLD
Muffler with tailpipe and good rear hanger $50
Front corner lights (OEM clear-ish) $10 SOLD
Front turn signal lights (amber, below headlights) $20 each SOLD
Radiator support $150
Gas door red (works with auto release, but no key) SOLD
Horns (pair) $15
Various coolant pipes (ask)
Door ajar switches $5 each
OEM power window master switch $75 SOLD
Steering column clamshell (grey) $75
Various ductwork pieces (ask)
Brake booster $50
Interior kick panels $15 each
Transmission tunnel cover $25 SOLD
Uncracked gauge bezel $60 SOLD
Passenger front door - dented, but still has guts (ask)
Two OEM Koito square headlights (one high beam and one low beam) $10 each
If you have. I'll call dibs on Rocker Panel Chrome trim on both sides if complete. Did t see it listed but thought I would ask.
Do you have the steering column switch assembly (wipers, signals, lights)? Pm me a price shipped to 96706. Thanks.
Yes, I have it. Let me measure it for shipping, and I'll PM you a price.
Thanks.
Dave, how's the center bezel? Are the tabs in tact and un cracked? If so shoot me a price. My brother @kmj64 desperately needs one. Also some good rear door panels if you have them in gray. Thanks. Jim
Hey Jim, just so I'm clear: the center bezel of what? Also, I've got some rear door panels in grey, but let me check on their condition. I know they're dirty, but they may be able to be cleaned......I'll just have to check.
Thanks,
David
Hi, I'm interested in front turn signal light and clear corner lights . Thanks, Mike
I'll take the (gray) steering wheel if the cover is tight and does not spin in the hands.
I'm also looking for:
1. an intact driver's side door card with no rips or tears.
2. The driver's A pillar grab handle.
3. The passenger front seat belt.
4. The amber front turn signals.
I'll pm you.
do you have the chrome "toyota" license plate bezel on the rear tailgate?
Are he speaker grills on the doors good? I'd like them
