That's been my experience so far as well. This seems to be just the opposite if it is indeed a vacuum leak.Doubt it's a vacuum leak. In my experience a vacuum leak on a 3FE results in low idle. For example if you pull the oil cap on the valve cover while the engine is running it will set up a vacuum leak that will really make the engine stumble.
Nada, thought or hoped that was it too.I had this problem on my Toyota pickup. Drove me crazy for months. It was worn out parts on the back of the gas pedal. Next time it's at high idle, lift the pedal up and see if the idle drops.
I cut my own TB gaskets, it's not hard to do, you can get gasket material at any auto parts store.I did, but not since this latest incident. I will do that again this week for sure. I need to take out stock in TB gaskets. This is one of those frustrating things to try and chase down.
Oh yeah I checked the dashpot alright. I removed that POS when I removed the erg. It was non functional anyway. The truck is now a 4speed too, so no auto trans to worry about.Have you checked the dashpot function/adjustment?
i’ve been having almost the exact same issue on my chevelle with a sniper installed. my throttle cable is getting hung up just a little but it’s enough to not let it return to idle. it’s like i have cruise on the highway. while its racing can you get it to slow down by manually pulling on the cable at the throttle body? it’ll tell you if it’s your cable if you can bring it back to normal by manipulating the throttle body side of the cable. mine is a brand new lokar cable and there was just enough of a kink in the routing that it caused my issue
Could have a few broken strands within the housing that you can’t see. It’s worth a try. It seems to have happened to more than a few of us.Thanks for the help fellas. It always is something stupid. I will keep looking. I guess if I had to put in a new throttle cable just to be sure that would not be the worst.
This is how I figured out that my choke cable was getting hung up on my 60.What @franklin40 said.
Next time it runs up don't stab the pedal with your foot, get out and manipulate the throttle cable cam attachment by hand and see if it pops back into place and rpm's drop.
I’ll freely admit that I haven’t analyzed the whole thread but…Right, like maybe the pedal is returning back to normal position but still the cable is pulled slightly to keep the butterfly open just a tiny bit. It seems hard to imagine with those heavy springs in place but you are right it does seem to have happened to more than a few of you.
