or did you just use your hand to play with the throttle opening?
Heh heh heh.
Glad you got it worked out Justin!
The bottom screw on the TPS is the problem child. I didn't have an angle screw driver, so I had to take the piece off that bolts on directly in front of the TPS (to the right of the TPS if you are standing on the side with the air cleaner). Be careful not to mess up the gasket. You can't move it very far because it has some little coolant lines attached to it. But you can move it away far enough to get a long screw driver into the bottom screw. Pop the electrical connector off of the TPS and measure the resistance (ohms) between the IDL and the E2 pins as you rotate the TPS. With the throttle closed, you should get a resistance measurement. Then if you open the throttle a little bit, the resistance goes to infinite. Close the throttle and you should get a measurement again. Tighten down the screws and put it back together. In my case, the IDL-E2 resistance with the throttle closed was way less than the maximum specified in the FSM. After I did this to mine, the idle smoothed right out, idled lower, and dropped to 650 rpm after it warmed up.
As far as the other TPM resistance values, the only one that should change (other than IDL) is the VTA pin. It should vary smoothly between about zero and whatever your VC-E2 resistance is as you open and close the throttle.
Good luck.
I went through and tried turning the TPS till the Ohm meter gave a reading with the throttle closed. Cleared the code and sure enough - no code 51! Yay. Start it up, and it won't idle. Booo...
If I hold the revs to 1700 I can keep it running, but just barely and its rough. Let go and it will drop to around 600rpm and then shut down.
Just as a data point, mine was always idling all over the map. sometimes 2k, sometimes 1k. Had a code 22 on the CEL and research here said that while it was stating that the Water Temp sensor was the ticket, it could be other things. I did the WTS and she purrs now.
Just thought I'd add that in there.
You have an old thread for EVERY SINGLE one of my problems!! My FJ62 thanks you and so do I!I've had my 62 since last May, and have been slowly working my way through all the issues that have accrued over the years--everything from minor rust issues to cooling system issues, to charging system failure, etc. Before I found MUD, and before the realization finally sank in that I was going to need to maintain this thing myself, I took it to an independent mechanic and then a Toyota dealer, to try to get a nagging rough idle fixed. A few hundred dollars later, it wasn't any better than before. The idle sat around 900 rpm (I thought maybe the tach was reading a little high) and was not smooth. Every 3 or 4 seconds it would cut out for a split second, and then come back.
Searching MUD eventually led me to the thread in the FAQ section about the Fuel Pulsation Dampener. I checked mine, and sure enough, the screw was out. I thought HaHa this must be it! I screwed it in, but no help. I noticed fuel stains around the dampener and so decided to just replace it. After I replaced the dampener, the idle cut out went away, but it still did not idle smooth and the idle sat around 900 rpm even after it was warmed up.
Today, I decided to just start going through all the EFI system checks. To begin with, I figured I'd put the ECU in diagnostic mode just to say I had done it. The Check Engine light had not been coming on (other than when the key was first turned on), so I hadn't felt the need to do this previously. I stuck the paper clip in the holes and went around to take a peak at the blinking light. Low and behold, I had an error! An error 51. The FSM pointed to several things that could cause this problem, but I was pretty sure they were all OK--except for the throttle position sensor. I wasn't sure about that. So I popped the connector off and did the resistance check as detailed on page FI 69. I had a problem! the IDL-E2 check with the throttle closed was infinite ohms. By loosening the screws, I turned the Throttle Position Sensor until I got a IDL-E2 reading with the throttle closed. Opened the throttle a little and the reading went to infinite like it is supposed to. Connected everything back up and started it up. Idled smooth as silk at about 800 rpm. After it warmed up for a few minutes, the idle dropped right down to about 650, just like the book says. And it was just purring along. I couldn't believe it!
So I learned my lesson. Number one: I am my own mechanic for this rig. Number 2: My first step in trouble shooting anything engine related is to check ECU diagnostics.
And yes I cleared the error, and then rechecked again after I ran the engine for awhile, and the error is all gone. Yippee!!!
