Wanted FJ60 Manual (78 Viewers)
I have a 72 housing (same as the latter ones, comes with minitruck knuckles, and alot of the brake parts.. you would need hubs, Birfs and inner axels.. bolts and stuff and a 3rd.. but all im looking for is about $125 plus shipping from CO
1958-9/73
9/73-1/79
and
1/79-1984
might be spendier than I thought, the early one was $20 but the latter ones look to be 3x's that!
LandCruiserPhil said:
I'm in need of a 1978
What year did they change ?
yeah, the one with the enamel on the inside of the letters is quite a bit steeper
malphrus
78-80 Distributor and Igniter wanted
Anyone have a 78-80 distributor and igniter? I'm located in Ohio. Thanks!
Dianna
THREAD NO LONGER NEEDED - Can be Deleted
I have acquired the trim - thanks Phil!.
Original Title & Message
WANTED: 1988 FJ62 Lower Passenger Trim
I have an 88 FJ62 that needs the lower passenger side trim piece that runs along the rocker panel under the doors.
Does anyone have any trim pieces that need a home?
Thanks, Lee
Fj-40 Tub
I still need a tub for a 78 Fj-40, as close to Colorado as possible, Aluminum or steel works, Thanks Brad.
FZJ80 Center Caps
Need at least 2.
Thanks.
FJ62 Passenger Grab Bar
Looking for a 62 grab bar on the passenger side. Grey interior to install in my 86 FJ60.
I'm in Moscow, Idaho, 83843.
thanks,
mike
In Need of a 1979 FJ40 Wireing Harness
I am in need of a 1979 factory wireing harness, I was a idiot and had a 18 curcit Painless installed by a moron guy and now it is all FUBAR. Can anyone help?
Thanks
Chris
I've got three from a 97 I don't need/want. PM me an offer, location, etc. I'm in Riverside, CA
Mike
80 series DS headlamp 1995-97
Anoyone have the driver's side headlamp assembly for a 1995-97 80 series. I've contacted Dan so I know what Toyota wants for them, just want to see if anyone has a used one they are willing to part with. Thanks in advance.
Mike R.
tough item to find used. i tracked down two of them and each had broken mounting tabs.
i think that i saw one on ebay the other day... it had two holes in the glass. :doh:
i ended up going new, mailorder from a dealer in NC.
good luck!
I've got one from a 77 made in Nov. 76 not sure how close it would be.
