Wanted FJ60 Manual (20 Viewers)
Are you looking for a one groove? I've got one still on the motor.
where are you located?
i've got a half decent ds door for ya if you're in the southeast...
malphrus
Still looking.
If anyone has suggestions on where to find some used wheels, I'd like to hear from you. I'm having a lot of trouble finding LX450 wheels and any yards around here.
I have a set I would be willing to part with, but shipping will be $$$ I also have brand new factory lugs and decent Michelins for all of them (5)
I am in NC.
PM me at rjhr@earthlink.net
Drivelines
I have swapped from 79 style square pinion flanges and output flanges to 86+ round style on the drivetrain of my 1980 FJ40. I need round style d/s flanges now too - does anyone have any suggections? Should I source flanges and swap them on the d/s's or should I get d/s's with the flanges and have them cut to fit?
Does anyone have FJ60 front or mini driveshafts for sale?
Thanks,
rjhr@earthlink.net
p/s hoses
Hi all,
I need p/s hoses for a 12/79 FJ40. I need the two that actually screw into the p/s box and the p/s pump. I have the cooler line.
Any out there f/s?
Thanks,
- RJHR@earthlink.net
Rick, I'd get the shafts with the correct flanges then resizing them to fit the 40. BTW, later 60 series fronts aren't going to have the double cardan joint, if that is what you are after.
Dave
sent you an email
spring trade?
Looking to trade - I have a set of new Alcan 4" springs for an FJ40 (pre-81). Rear are centered. Willing to trade for a set of OME 2.5" springs.
I do not need the height, I don't think.
I am in NC.
FJ40 parts
I need a plastic upper heater cover (mounts on metel base with heater core inside) for a 1982 we are restoring and in desperate need of the rubber gasket under windshield.
Thanks
Rob
www.raddcruisers.ca
need a GBS or status monitor for an 80
Some knucklehead PO wanted to try out his new Wal Mart wire cutters and cut the wires to the status monitor on our 96 80. :confused:
It is an RS3000 system. I really need the Glass Breakage Sensor as the wire to it is gone. I can use the LED as it has enough to splice, but if you have the whole status monitor (especially a vertical one) with some wire that would be cool. :bounce:
And if anyone would have an intact harness to the RS3000 or even pieces let me know as I would like a certain chunk the idiot PO proudly tossed in the trash before the aforementioned wire cutters went south after 10 minutes. :eek:
Let me know if you can help, or just happen to have some pretty wire next to a pair of cheap wire cutters. :mad:
door strikers for a 74 40
Need strikers for a 74 fj40.
I can get a pic if needed off of another post by someone looking for the same thing.
I just didn't want to hijack a post. :idea:
BJ60 A/C Amplifier
Need BJ60 A/C amp for my FJ60/13bt swap.
Will trade for a FJ60 amp or BJ74 amp as well.
thanks,
mike
moscow, idaho 83843
82 fj40
I'm parting out an 82 fj40. Can you send me a pic of the heater part? I will look at the windsheild gasket.
you could have hijacked my post, I bought mine from 3_puppies so Wadester might still have his available Wadesters@Peoplepc.com I'd give him a try!
Cross Member support for my 1972 40
I am Looking for a Cross Member support for my 1972 40...
I believe Advanced Adapters makes one that mounts the the rear of the xfer case.
thanks,
manny 72fj40
