FJ60 crank pulley nut
Does anyone know the size of the nut on the crankshaft? My pulley broke and I have to replace it. The problem is that it is about 5 hours away so I can't measure it lol. Thanks in advance.
Plano texas
I do know I had to buy a socket from snap-on ,could not find one else where. mike
Denver, CO.
It's 46mm IIRC, I think the socket I used was a 3/4" drive 1 15/16" Craftsman with a 3/4"-1/2" adapter. The standard Craftsman socket/adapter combo will probably be easier to find than an actual 46mm socket.
Brad
Thanks for the reply Mike. Do you remember the size of the socket? The main problem is that the vehicle isn't near a town/city with any type of socket store thus I am trying to return prepared with the correct socket size. I should have measured at the time but spaced it.
Spike Strip
Goblin Mode Activated
Lost Angeles
46mm = 1-13/16"
SK Hand Tool 34096 - 46mm Front Wheel Bearing Retainer Socket - 1/2 Drive Impact
1/2" drive is a little easier to work with since most people don't have 3/4" air tools or ratchets. Also, the 1/2' will fit with the rad and shroud still in there.
Boise, you know there's an aftermarket crank pulley that's avail that's solid and much cheaper than an OEM... You buying used or new ?
Denver, CO.
My bad... couldn't remember right off hand.
Brad
46mm = 1-13/16"
I picked up a used one to at least get me through a little while. I tried to get the aftermarket but the places I tried had it backordered. I've had good luck with the used parts from cruiserparts.net so I'll give it a shot. It also cost about $217 less than the aftermarket part and about $535 less than the toyota part.
I haven't changed a crank pulley before. Is it very difficult?
Thanks for all the info everyone. Much appreciated.
Scott
Spike Strip
Lost Angeles
Start spraying (or have someone spray) the nut with PB Blaster, etc.
Search for threads on using the starter to bust the nut.
Pighead
Stop calling it an FJ
Camino
You might need a good puller to get that pulley off...
Glenwood Springs, CO
If possible I would befriend the local Toyota folks. I have managed to build a pretty good relationship with the guys at the local Toyota and they have let me borrow a couple of the specialized tools that I have needed....including a 46mm socket for the crank pulley nut on my 60...
Spike Strip
Lost Angeles
Where do you live, NeverLand ??
And I don't mean Michael Jackson' old ranch...
:D
Dynosoar
Slightly Disturbed
SoCal
Be sure to change the seal while you have it apart.
Dynosoar:zilla:
