FJ45LV rear shackle substitute
El Paso, TX
Hi there.
So, as I can't find stock rear shackles for my wagon, am I able to use the 80+ FJ40 shackles with no problem as long as I use the correct bushing?
Go here for info but 45 rears and 60 rears should be the same as well as 55. I am pretty sure i used some leftover OME Fj60 shackles i had in the garage.
https://www.sor.com/cat289.sor
thought he was asking about shackles tho? Either way, that chart will help you with ID, OD and shoulder width to match whatever it is you come up with. I just used some shackles i had on the shelf and ordered bushings to match my parts.
