The 1978 FJ45 lives again! Over the past few months, I've put 300 to 400 hours into it; it's good to be retired and have the time for this.
The frame was good, except for a couple of thin areas on the inner frame behind the cab. These were repaired with new metal. The box came off and was replaced with a slightly better box from the other FJ45 project. Still, the box needed a couple of weeks of metal replacement. Put Rhinoliner on inside box. The cab got a new support system under the back end, floor patch panels, new cab corners, new rockers, new fenders, etc. The repaired areas have two coats of epoxy primer on them, which should do until I get around to a repaint.
All four springs were disassembled and rearched to original specs (plus 3/4 inch). OME shocks on rear, Bilstein 5100s on front, OME steering stabilizer. New dash pad, new interior door panels, etc. Rebuilt carburetor, Haven't installed running boards and a few other parts yet.
It runs and drives nicely. Not sure if I will get around to doing the same to the 1977 FJ45 or not - it's a lot of work to bring these back to life.
