Hey guys, please help me out here Im stalled. My (73) FJ40 sat at a local shop for about 4-5 months as it had the roll bar built and installed. Before I dropped it off everything was functioning properly, when I picked it up it and trailered it home. I tried to drive it when I got home with it and it would not shift into gear while running. I could try to force it into gear but it would grind and not go into the gear. I am physically unable to shift it into gear because it grinds. Thats when I first noticed it was leaking brown brake fluid from the slave cylinder all over my driveway. So I replaced the slave cylinder, the hose, and the master clutch cylinder and bled the line. I tried to run it again and again it is not able to shift into any gears. So I begin messing around with the transfer case. In every option 2l 2h 4l 4h it will not shift into gear while running it grinds; HOWEVER when the transfer case is in neutral the car is able to shift into gear while running. If the car is not running it shifts fine. If the transfer case is in neutral the car shift fine while running. Any other option results in grinding and will not shift. Please help me! I need to get back on the road asap.
