pbgbottle
Forum Lifer
- Joined
- Feb 8, 2004
- Threads
- 288
- Messages
- 5,553
- Location
- Cloverdale B.C. Canada
- Website
- www.instagram.com
If ya pull the driveline drum gear oil will spill out your gonna have to some mods there also.
I’d love to see a schematic. I was looking at the pantera controller for these. Then I’d just need to figure out the bracket.Got my calipers done, installed & checked out.
Using a direct switch control. Let me know if anyone wants to see a schematic, or wants to buy my (unused) pair of “1 touch” power window controllers. I’ll give you a good price!
Rocky
great pictures. Thank you for sharing. I am considering the same. fj40 1971, Chev 327, T350 trans. pwr steering, brakes. My axle is heavier than the stock for this vehicle so mounting the disk brake calipers with the standard bracket just diden't work. Your bracket for the epb is clean, compliments. if you still looking for the switches for wiper and pull lights I will find my source and report back? I have the Painless wire kit, not yet installed. I am waiting on completing the body work. This seems to be a great forum, as I have found great information. Thank you to everyone on the forum btw.View attachment 3796095
View attachment 3796101View attachment 3796103Finally got this one done! The ol' disc brake on the driveline thing was not working for me. This is a daily driver and she needs some time to warm up in winter, not to mention just being safe- a bolt down speed bump in the driveway worked for a few years on the warm up but offered no safety. I went for the Wilwood electric e-brake kit, which included both calipers, switch, controller, and harness that I purchased from Summit Racing for about $1300. I was not stoked to spend that much on this but would do it again in a heartbeat, given how it came out. The calipers came with mounting brackets that I had to change, so I drew some up on CAD and had them laser cut. They mount opposite the disc caliper and utilize the bolt pattern on the axle, hitting the top and bottom of the flange most rearward on the axle. If you're looking at the wheel from the outside of the truck, my brake caliper sits at 8-9 o'clock, and the new e-brake calipers sit at about 2-3 o'clock. Running the harness was not a big deal- there was plenty of length. I have the controller mounted to the very outboard wall in the glove box, safe from the elements, with the power coming right through from the battery on the other side of the firewall. Mounting the switch was probably the most tricky for my dash, which is wonky enough already as a result of some PO hackery. The Wilwood system does NOT use power while the brake is idle, either on or off, so no parasitic draws to worry about. It only uses power to engage or disengage. The switch has a nice LED ring around it to let you know it's engaged. The brake is rock solid!! Was parked on a steep hill with a trailer the other day and she was just sitting there, happy as can be. I like the fact that it's both wheels. I have been trying to solve this off and on for a while now, and couldn't be happier with the way it turned out. I had a few hiccups with the system- the LED ring also acts as a flashing code indicator if something is off. It was throwing a voltage code on the left caliper, so I called Wilwood and they immediately sent out a new caliper which fixed the problem. They were absolutely fantastic to deal with on all fronts. Love any customer service in this day and age, but they were next level for me!! One of the top 5 best mods I've done to date.
I apologize for any formatting awkwardness on the post. First time posting pics.
always fun to share build stories. It's a sure-fire way to learn!! Absolutely, report back on wiper and light switches!! Would love to know. Where are you mounting your Painless fuse box? I chose poorly on mine by mounting on the engine side of the firewall, and am paying the price in the end- wires have to go into the cab and back out, so double mess through the firewall. May redo it purely to simplify. If you are comfortable with Amphenol style connectors, I highly recommend looking into multi-pin connectors that lump like things together for ease of tracking stuff. If I had it to do again, I'd do an engine bay group, rear of vehicle group and an accessory group. Sure would keep it easy to find and/or add stuff and keep the theme consistent. Wiring is new to me and like anything, you learn as you go so mistakes get made. The investment in crimping tools is worthwhile. IWISS makes decent ones for that style of crimping, which is the same as the "Deutsch" style connector. I also have loved the hydraulic crimper that harbor freight sells, to do battery and larger connectors. I have had FANTASTIC service from Pro Wire USA for Deutsch connectors and high quality TXL and Tezfal wire (https://www.prowireusa.com). Not affiliated, just a happy customer. I used the American Autowire Power Plus 13 wiring package and they also have amazing customer service. Definitely needed some help with the hazard and turn signal circuits. Cheers and happy journeys.great pictures. Thank you for sharing. I am considering the same. fj40 1971, Chev 327, T350 trans. pwr steering, brakes. My axle is heavier than the stock for this vehicle so mounting the disk brake calipers with the standard bracket just diden't work. Your bracket for the epb is clean, compliments. if you still looking for the switches for wiper and pull lights I will find my source and report back? I have the Painless wire kit, not yet installed. I am waiting on completing the body work. This seems to be a great forum, as I have found great information. Thank you to everyone on the forum btw.
I bench tested them using a M12 cordless tool battery and it worked fine. I think crawling under the truck to do that wouldn't be too big a hassle.The little reading I have done on modern electric e-brakes mostly agrees with the fact that the brakes will be stuck on (or off) in the case of a dead battery. It comes up on various OE forums (Honda, etc.). In the event one cannot get a jump start, or enough power from a portable unit to release the brakes, it could be a bit of a PIA to get them off. In the case of the Wilwood, the mounting bolts are accessible without removing the wheel. Once the slider pins come out, the pads are no longer connected to the caliper and may be possible to wiggle off. Hard sayin'.
