You won't be off, it'll go together right as rain.Thank you @Brian/99uzj100. Looks like I remove the axle side...pull the driveshaft apart, rotate 90 degrees then reinstall the sleeve. If I am a tooth or so off, will that affect it?
I just swapped mine front to back, cleaned it up, and re-greased it. I'll paint it when I change out the U-joints, but for now they have no play.
I also had to pull it apart and rotate it 180 to get all of the grease fittings on one side per the FSM.
Before:
After with grease fittings corrected:
Hijack over...
