I have always figured that the factory guys know their stuff. While there are plenty of aftermarket external electric fuel pumps supplying fuel to a variety of engines, I believe the correct place for the pump is in the tank. There are a couple of good reasons why the factory put the pump in the tank:
I looked at a number of pump setups online and decided the 90-93 GM/Chevy Pickup pump would be the easiest to modify, and the 5.7 TBI I have is the same vintage. I started my mission by buying a complete gas tank out of 93 Chevy Pickup, knowing I would need several key parts from the tank to get the pump to install the same as the OEM version.
This is the top of the GM tank,
Here are the parts I needed from the GM tank, including the stamped recess from the top of the tank.
Next job was to decide how to modify the OEM pump assembly. I could have purchased the pump assembly brand new for $230, but the complete tank and used assembly was only $35, and $45 for a new pump. Besides, I planned on chopping it up and couldn't justify cutting up a new one for an 'experiment'.
After some preliminary measurements from the FJ40 tank, this is what I came up with for an initial mock-up.
Next came the nerve racking part, cutting into a brand new FJ40 gas tank. The challenge was determining the exact location of the baffles and determining the final, permanent location for the fuel pump. I also had to take into account clearance issues with the passenger side seat. My seat are not stock and have plenty of room underneath, but there are some I had to make some provisions for the power seat mechanisms.
More tomorrow.
- It keeps the pump cool by immersing it in the fuel.
- It provides the shortest distance from the tank to the pump.
- You don't have to listen to the pump buzzing.
- It accepts a OEM replacement pump. I have learned the hard way that not all external electric pumps are set up the same, making emergency replacements a challenge.
- The in-tank pump is half the size of it's external cousin.
More tomorrow.
