FJ40/2F carby; rich idle.
Maybe try an "Okie Rebuild" to clear debris that may be preventing the primary and/or secondary barrels closing.
Run engine up to about 2500rpm.
Cover top of carb to choke and kill engine - some use their hand - I use cardboard (with a hole for the AC screw), in case of backfire.
When engine dies, remove cardboard.
Restart engine and see if idle and idle mixture screws kill the engine.
hth
Here's another trick I've read about, but I have NO experience with it - it suggests a bit of automatic transmission fluid in the carb, to clean out carbon. Here's a video YOUTUBE
I would read all I could find before trying it, but many have reported good results.
hth
Set the knob or display on the back of the timing light to 10*. Then twist dissy to bring the pointer to the line.
If the light doesn't have a knob, then set timing so the BB is toward the bottom of the window.
Are these all correct?
Firing Order 1-5-3-6-2-4
Spark Plug Gap 0.8mm (Conventional Ign) 1.0mm (Semitransistorised)
Contact Breaker Gap 0.45mm
Dwell angle 41 degrees
Ignition timing 7 deg btdc
Idle speed 650rpm
Valve Clearance (hot) Inlet 0.20mm; Exhaust 0.35mm.
Your numbers all look correct.
Forget about point gap, that is just an approximation. The number that counts is dwell time (how long the points are closed, charging the coil.)
My entire life I agreed with using the dwell rather than the point gap because, as Jim points out, that's what matters.
However, on this vehicle only, for some reason setting the points to the specified dwell results often results in the points being dangerously tight.
A lot of people here have found this.
Here are a couple of threads on the subject.
https://forum.ih8mud.com/threads/points-gap-verse-dwell.675686/
https://forum.ih8mud.com/threads/bizarre-dwell-and-point-gap-question.517077/
I guess what I would do is to use the dwell and then measure the gap. If the "proper" dwell results in a point gap that was way tight (like under .010) then I'd use the gap instead. It looks like this poster has a reasonable point gap and dwell so there's no issue.
I set an early vac advance distributor at 0.018 as I recall and I'm getting a perfect 40-41 dwell. So sometimes it works I guess.
Pin, the dwell is not as important on the 75-77 USA engines because the big transistor charges the coil magikally. The points only provide the break open signal to discharge the coil.
It's amazing the difference a quick points gapping and ignition timing makes.
Points gap was about half what it should have been and the timing was set to TDC. sounds a lot smoother now.
I unfortunately don't get much time after work to tinker so I'll do everything on the weekend from start to finish.
Question: I'll be doing my valve clearances as well, what order should I do things in (if there is one)?
Clearances, gap points, gap plugs, timing, carby tune?
