I recently purchased a Dec/74 FJ40 in Washington State and drove it back to Southern CA in 4 days. It's been mechanically gone through and runs like a dream. It's original 1.5F engine (included) developed a crack in the head and was swapped for a 12k 2F w/ 4 speed on the floor. The tub has rust in the rear corners and pan. However a replacement Tub was included in the purchase. My plan is to drive it for a bit, then pull it completely apart and do a full frame up restoration.
I would like to add a mini box power steering (only want to go to 31" tires max) as well as fit it with a PTO winch.
It runs beautifully my only real issues out side of rust at this point are; the windshield wiper motor burnt up while in use.. I'm going to try to clean and rebuild it. If not swap to a blue bird and modify the mounting plate. My other issue is that the heater (under dash on tranny housing) blows hot air at all times. Maybe I just don't know how to properly turn it off but it blows hot all the time in all positions just some hotter then the rest.
Between the heater and the engine heat with it 105 degrees out (live in the desert) it's brutal!
Thank you,
Mark
