Builds FJ 45 Extended Cab Custom Vehicle Build Finally Begins (4 Viewers)
What is the cable selector for on your shifter...I have tried to keep up with this build but may have missed what is was for.
5-speed chain-drive transfercase, it's a Shimano :)
(Hand throttle it looks like)
The first inner fender skirt in place.
The Shock Hole got a whole lot longer.
I am down to the gibblet stuff that seems to take for ever.
Items are either at the powder coaters or ready to go to the powder coaters so final assembly seems to be taking for ever.
Rear hatch door hinges and hardware. Inner Panel is ready to install after I get the two broken bolts drilled out and the latch mechanism adjsuted after the hatch is adjsuted, etc.
sure is nice when it's done though...good job!
Great job Dan.:clap: Your maken head way. what kind of cupler is that you used to connect the shift lever to the tranny top plate stub. If that make any sence.
Joe
Those of you who have done the Big Motor upgrade have ran into the problem of the cover no longer fitting.
Installing the Big Motor/Big Cover would involve drilling 4 holes and mounting the cover.
LOL!
Nothing has been easy so far, so I got all Eshan on the cover. LOL
Time to work on the Duct work.
Many of you know that 2 1/2" silicon connectors are plentiful from several supplies. Many of you know that 2 1/2" connectors don't really fit the heater box or the duct work.
Sleeve them.
I really did not feel like removing a bunch of stuff to drop my windshield just to drill a hole for the wiper motor wiring.
Weather Pack connector used to add some length.
Ran the wiring though the defrost duct. Protective sleeve used to protect the wires.
