- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 13,327
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Thanks @HardyDanger for the detailed writeup! I had the exact same leak pattern on the jack and other side of the truck as well- so this was really helpful.
In my case, it was the exhaust vent duct that was leaking. I can see the leak happening from any of the clip holes as well. The path of water from the gutter happens to perfectly run every hole in that vent area! LOL
1. access hole for the 8mm bolt that holds the cover plate-use a magnet, it's too fiddly to chance dropping it. (access for the top mounting clip pictured by @AussieMick80 two posts up)
2. red is where seals dry out and start leaking. Green line is the path of water from the gutter. Basically seeps in behind the duct, runs down the side and into the vehicle.
The duct is very thin blow molded type plastic so it can distort, not lay flush w/ metal once the adhesive dries out.
3. vent assembly. Once cover is off, unscrew (2) and pry out baffle assembly w/ spudger, then duct can be pulled out.
4,5. pics for demonstration- kudos to hardydanger for applying tape to the thin rubber trim!! No way I have the patience. I used butyl rope and stretched it across to stick the trim down and adhere to the body.
Also used it around the duct to seal it. (photo just for demonstration- you have to clean well and apply rope with care before mounting)
additionally, I used butyl to seal the cover plate on since a couple of my clips were broken. Bummer. But, it does weather seal the cover much better than stock this way.
I'm not advocating using butyl rope over any other method, it's just a good solution for me since I have it on hand and it seemed appropriate for the job.
*as OP mentioned, getting it the cover trim back in under the rubber lip can be a challenge- just use rubber lube and it will slide in easily with a spudger.
Toyota used butyl just like this for the flapper inner vent part.
You can put a small dab of seam sealer on the nut before installing from the backside.
I use butyl to get the gasket on the louver to stay in place. Just a real thin bead. Even with brand new louvers that double sided tape sucks.
The louvers are very easy to install if you do it before the sliding window gaskets. Not many people doing it that way though.
Cheers
