First FJ 40 Build Thread
Final mock up photos. It’s already been torn back down to the drivetrain. Was fun to look at for a couple weeks. Now it’s finish work and brake system 🤮
Great job on the project and the color is fantastic. Can you tell me about the steering column you went with? Is that an "ididit" column? Did the firewall plate come with it or did you have to make it?
Thanks!
Drake
Fantastic job! You should be quite proud of the job that you did.
Thanks!
Drake
Yes I just used the ididit column for a standard GM. I made the lower mount plate myself. Just used a collar and set screws to secure the bottom of the column.
Thanks for the reply and it all looks really good. Did you run into any issues with the Ididit column or was it a pretty smooth install?
