white letters in. let the size of your rubber do the talking!!
Thanks. The wheels and frame are painted with acrylic urethane paint. It looks good and is pretty durable. The color is a dark charcoal. I don’t have the code for it because it was a mistake can that I got cheap at the auto paint store. It’s not a Toyota factory color. I just wanted a charcoal and wasn’t too worried about which one. The problem is ever needing to fix it. I have a gallon and plan to use it on bumpers and accessories. I hope to have some leftover if I ever need to repaint somethingDid you powdercoat those wheels? What color did you use? They look good!
1. If you bought new LS square front motor mounts, I'd buy your old triangle mounts (unless you just used adapters).
2. For rear tank look at my ebay #264033688625 and #253592985106.
3. Your Saginaw installation was horribly home made, I believe you need all but the actual gear box replaced, I can provide more info on this through PM. But in the mean time look at my ebay #261702058064, it would dramatically clean up your steering plumbing.
Maybe most wisco folks are smart enough to stay away from these things!I'm just glad to see another Wisconsin Cruiser fanatic cause it's lonely here![]()
I am over by Milwaukee and about 20 years ago I bought every FJ40 (and 1 FJ55) I could find in a 50 mile radius. Wish I still had every one of themMaybe most wisco folks are smart enough to stay away from these things!
Love the winter. Haha you wouldn’t love this. That’s why I’m doing this projectHi mate.
Jealous of your winter and your truck! Love the V8's and love the earlies. Can I make two suggestions?
- Install the ribbed '67 dash into your '68. Much classier!
- If your budget allows, run a split case transfer. They're far superior and the 'propellor' type crossmember on the one piece case is prone to leak, especially given the LS has more torque than the F135 ever had!
Ace build mate, keep it up!
I remember those winters around Elkhart Lake. Not much you could do outside without skis or snowshoes, lol. Great build, perfect inside job!
If you haven’t done anything with those FST tailgate hinges on the original yellow tub I know someone who could use those.
[/ I still have them if you need them
