For Sale Few early parts
sofj45
Supporting Vendor
Year
1964
going thru boxes organizing and finding things I won’t use or have doubles or triples of. Some is stuff I’ve bought from different members and then they just sat in boxes so why not pass along if anyone needs.
Locking gas cap never been used. Both keys attached $SOLD
Early mirror needs cleaned up, or is useable as is for the right rig $SOLD
Lower rad heater union $25 shipped each
Vader lamp switch. Not in great shape and missing the nut to hold to dash. If someone truly needs it cover shipping and it’s yours.
Interior door pulls. One is covered in black spray paint im sure will come off easily with some paint remover the other is decent. $100 shipped
Master cylinders as a lot all together. 4 tin cups. 2 brand new brake masters. 4 extra plastic cups. 5 extra masters. 2 brake line end caps one clutch end cap. Rebuild kit for both clutch and brake. Misc parts and pieces. $600. There’s enough to do one full set new clutch and brake with placing tin cups on new masters. Then more s*** for the shelf
Will be continuing to go thru parts and then onto the 55 parts as my wife’s project is winding down.
What mirror was it? If an interior mirror for ‘65 that has the three holes in triangle pattern I don’t want to know 😂.
Nope if it was it would have went to you already, was the early mirror. That one came out of my green 62 i pulled a better one from my 63 40 since the cage blocks everything and then had this one floating for a while.
I have a 63 Swb fixed top and I have a Vader light but no switch. Did they come with one or were they wired into the headlight switch? If so I’m interested. If they didn’t then I don’t need it.
So the vader light was on whenever the headlights were on? Would this be a three position headlight switch? Can’t imagine why that light would need to be on all the time with headlights, seems like a distraction in the making.
From 1961 users manual
From 1964 users manual
Nothing in either case about room light from headlight switch
Yes when I have my headlights on the Vader light is on, I just turn it towards the fire wall unless i need to look at a map. :)
It must have been carried over from the 20 series for a short time on 40s and 45s until the actual dash switch was introduced.
Well there you go 😂. The “Dash Lamp” is the vader light?
From the 1961 manual, same as your wiring diagram pic 👍
